shadow effect
Samantha shared this question 7 years ago
Is there a way to give rectangles, dynamic panels or text boxes a shadow effect?
Example of desired look is the document block on the right hand side of JIM tutorial page?
There's no direct way to do that. But you can place a rectangle above the thing you want to have a shadow. Then paint that rectangle in grey, for instance, and change the transparency level of it. The effect is the same as a shadow but the way to do it is a bit tricky.
This feature has been included in version 5.6
Hi Victor,
is there a way that can make the text look more crisp?
it always look nicer on photoshop, but when i use the same font and everything in prototyper, it just lose all the crisp
