set the default styling of JIM stock widgets
Ron Schlegel shared this question 4 years ago
I would like to set the default styling of stock widgets (while keeping them in the stock widget library or menu).
Comments (4)
Could you detail a bit further what do you need please?
Victor,
For example, I would like to to set the Label widget so that it is in 9px Arial bold by default.
I would lkie to set other widgets so they are set to 9 px Arial by default.
This would prevent much rework each time I drag a widget onto the screen.
Go to Templates, right click on the default template and select Edit Template Style. You will be able to define the default styles there. Also, you can select a widget in the canvas, go to the Properties and select 'Set as default style' option in the menu
7e60431987be71460c5b69aa545d1653
thank you!
