Set drop down list size
Love Cincy shared this question 7 years ago
Is there a way to set the size of the drop down box with the 'Select List' widget? I have a pretty long list of 'departments' and by default it is only displaying 5 items when you select the drop down list. I would like to format how large that area is. Thanks!
Well if you want a fully customized 'Select List' I would suggest you to create your own widget since the 'Select List' is quite limited. You can use a static list of options or use a Data List for a more realistic case. If you need help creating these drop-downs, check out the following examples:
Drop downs
Regards
