Screen resolution of prototyping tool itself?
Ivy Chen shared this question 3 years ago
I'm working in JustInMind on a very high-res screen, and the icons in JustInMind are minuscule, which is affecting my workflow/straining my eyesight. Changing my native screen resolution doesn't work, what else can I try?
Thanks in advance!
Dear Rrao,
Look for and launch this file and it will fix the issue:
C:\Program Files (x86)\Justinmind\Justinmind Prototyper 8.3.1\JustinmindPrototyperHiDPI.exe
Comments (9)
Sent email to Jim. Maybe good to add the installer to your website.
i guess there is no weekend support?
Hi Roh,
As mentioned at the other thread, currently there isn't any special installer for HighDpi devices. The current Justinmind installer has two versions and there should be two shortcuts, one to the HighDpi version and one to the other.
Look for and launch this file:
C:Program Files (x86)JustinmindJustinmind Prototyper 7.3.0JustinmindPrototyperHiDPI.exe
Thanks - that worked... it would be good to add this info to the download steps so it is not an extra step for the user or you.
Hi Roh,
You're welcome! I will transfer your suggestion to our content team.
I also need the high res installer. I am currently evaluating the tool and it is very hard to see things with the font and image sizes being very, very small. The recommended resolution on my Dell laptop is 3840x2160. With this resolution, it is extremely hard to even work with the software.
As suggested above, I looked for the high res installer but there isn't one that comes with the current installer that I downloaded from your website.
Dear Rrao,
It seems updating the version requires you to redo this step as the shortcut has been removed from my Windows taskbar. Would be nice if it remained.
Dear Smith,
Thank you for your suggestion! :)
