Save user input while using app prototype
jcfields06 shared this question 7 years ago
How can I save the input selected by a user (as with a drop down menu) so that it always shows up on another screen until changed again by the user?
I did use variables and I was able to display the information on another screen. However, when I move on to other screens and then return to the original the information has disappeared. Could this be because the data input by the user is done with drop down menus?
You have to define an event on the original screen like that : onPageLoad -> select value -> drop down -> value is -> variable. You have to use the 'select value' instead of the 'set value' because the 'set value' on drop downs changes the values in the dropdown. This tutorial show the difference between those two actions :http://www.justinmind.com/tutorials/m...
