The attached image tells the story much better than my words. Please review it.
Roboto Medium renders as heavier than Roboto Bold. The hierarchy of font weights is not correct and it's impacting my ability to design every day.
Roboto is our main platform font and Medium is our main highlighted font weight... but I can't use it. I have to use Bold instead. And then I have no Bold to contrast against it.
Anyway... just look at the image... it's immediately obvious.
Furthermore, the JiM editor is artificially 'squashing' the typeface as well. Look at the letter o in both examples... it should have a slight oval shape like the Illustrator example... however, in JiM it's perfectly circular as if the whole thing were being squashed downward by a few pixels.
It's just not rendering Roboto correctly... across the board.
Please fix this asap.
If you are having problems with the Roboto font, look for the Roboto font inside the Justinmind folder and install the one that comes with Justinmind. To do this:
1. Right-click on the Justinmind application
2. Click 'show package contents'
3. Open 'contents'
4. Open 'resources'
5. Open 'Java'
6. Open 'Fonts'
7. Click on the Roboto fonts to install them.
+1. I'm not sure why Roboto is so messed up, since you can freely download it from Google Fonts, but it's going to be a very common need for anyone who designs Android apps or uses Material.
Hi all,
Thanks for letting us know you're seeing this error. We're working on fixing this right now, and I'll get back to you ASAP with more info.
Apologies for any inconvenience.
Hi all,
We're currently looking into this issue. For further investigation from our engineers we will need the following information:
1. Which OS are you using? And version?
2.Are you using any font manager?
3. If possible, can you try installing the Roboto font directly from Google and let me know how this works for you?
Thank you in advance.
this was an accidental comment... ignore. (but still keep trying to fIx roboto!) :-)
Currently on
Apple Macbook Pro
MacOs Sierra 10.12.5
No font manager.
I tried the same things as James-uninstalling and reinstalling.
I am having a similar issue using a new Google font which I downloaded with the new version of JIM. The font is downloaded however it isn't render in simulation mode or when using the app on the phone.
Apple Macbook Pro
No font manager.
So I saw that there was an update relating to Fonts.
It claimed to be a fix for the issue where characters were getting garbled in the editor.
I updated the editor and checked and now I'm not only having the issue where the Roboto weights are incorrect now I'm also seeing the garbled text that was supposedly fixed in 8.1
I've attached another image so you can see what I am seeing.
Dear James,
Can you try to uninstall the Roboto font from your computer? That should fix the issue.
Sonia,
I just opened a prototype on my home laptop. It was at 8.0. It was able to display Roboto Light normally. Although I WAS still having the aforementioned font weights issue where Medium was heavier than bold I wasn't having a problem displaying the characters themselves.
So I just updated the prototype to 8.0.1 and now all the characters are garbled, just like on my work laptop (which also had no problem until I upgraded to 8.0.1 and now displays completely garbled characters in the editor as well)
I tried uninstalling Roboto, restarting my laptop, reinstalling Roboto, and reloading the prototype... still the same result.
In the editor the characters look like Gaelic when I'm typing and when not selected they just look all jumbled and overlapping.
In the simulation everything looks normal.
To recap:
2 laptops updated w 8.0.1
Both had Roboto uninstalled and reinstalled
Both are displaying incorrect font weights
Both are showing two different garbled character views in the editor.
Thanks for your continued investigation of this matter
Dear James,
Can you try uninstalling Roboto from your computer without reinstalling? Then restart Justinmind.
Ultimately... users shouldn't have to install a separate version of Roboto from the JustInMind folder.
But for now this worked really well and you can mark this issue as resolved.
I have the same font issue with Roboto, it doesn't display properly. I am using a macbook and I cannot find the folder of which you guys are talking about .
"Roboto font inside the Justinmind folder". Thanks
3. Open 'contents'
4. Open 'resources'
5. Open 'Java'
6. Open 'Fonts'
