Roboto font in cyrillic
Galin Dimitrov shared this problem 21 months ago
In Progress
Since the last update (that came to me in the last hour or so) the Roboto Regular font is not displaying correctly in Cyrillic.
I am attaching an image to see what exactly is the issue.
Roboto Regular is not displayed correctly in the editor although Roboto Thin, Medium, Bold and Black are rendered just fine. Also in Latin there is no issue. When I simulate the prototype the font is rendered correctly, I tested it on device and there it works fine as well, so the problem is only in the editor.
The app that I am currently prototyping is in Cyrillic completely and it uses Roboto Regular for the primary font.
This is a big problem for me because most of the apps that I am designing and prototyping are in Cyrillic and if I can't see what exactly I am designing I can't work.
Comments (8)
Dear Galin,
We're currently looking into this issue. For further investigation from our engineers we will need the following information:
1. Which OS are you using? And version?
2.Are you using any font manager?
3. As a workaround, can you try installing the Roboto font directly from Google and let me know how this works for you?
Thank you in advance.
Hi Sonia,
Thank you for investigating this problem.
I am currently using Windows 10 and I am not using any font manager (and never did). The font was installed on my computer when this problem occurs but I removed it and installed it again but no change on the issue.
Regards,
Galin
An update just came and now the whole Roboto font family is not rendering correctly.
Can you try to uninstall the Roboto font from your computer? That should fix the issue.
Yes, I did that and now everything is fine. Thank you very much!
Good! Now, if you want to use Roboto in any other application than Justinmind, look for it inside the Justinmind folder and install the one that comes with Justinmind. That way you won't have any issues with the font again.
I installed Roboto from Justinmind folder and everything works perfect now - in the prototyper and in the other programs.
Thank you once again!
Great. We're glad to hear that! :)
