Range Slider implementation issue
Sheraz shared this question 9 months ago
I'm trying to build a range slider which would select a range between given two values. I'm using two ellipses and lines for the slider. The problem is that the ellipse on the right can cross the ellipse on the left and vice verse. I don't want that to happen. Also the blue line which appears should just be between the two ellipses.
Kindly download the file from this link
Check out the attached prototype, which modifies yours to achieve what you're looking for. Hope this helps.
Thanks !!! This will work for me
