Prototyper trial version will not launch in OS X 10.6.8
webmaster shared this problem 7 years ago
I have downloaded the trial for Mac (ver 4.4.1) but it fails to launch. Each time I try to start the Justinmind Prototyper app, I receive the following error dialogue:
"An error has occurred. See the log file".
I have included the log file below. It seems to be some sort of problem with Java/Eclipse?
I am using OS X 10.6.8 and I have tried reinstalling both the entire OS and just Java alone.
I note other users have posted similar problems bit none of those threads have a resolution included.
Any help or advice would be appreciated as I'd really love an opportunity to evaluate what looks like a great app.
Thanks...
+LOG DETAILS
!SESSION 2011-12-09 02:31:31.244 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_15
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/Damian/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.1.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86 -data @user.home/Justinmind/4.4.1 -keyring /Users/Damian/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.1.app/Contents/Resources/Java
!ENTRY org.eclipse.osgi 4 0 2011-12-09 02:31:37.804
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
at javax.xml.parsers.SAXParserFactory.newInstance(SAXParserFactory.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.createService(EclipseAdaptorHook.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService(EclipseAdaptorHook.java:142)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:138)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:136)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:450)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:980)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:185)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getXMLParser(RegistryStrategyOSGI.java:304)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1062)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1040)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.addBundle(EclipseBundleListener.java:184)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.processBundles(EclipseBundleListener.java:90)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.onStart(RegistryStrategyOSGI.java:224)
at org.eclipse.core.internal.registry.ExtensionRegistry.(ExtensionRegistry.java:725)
at org.eclipse.core.runtime.RegistryFactory.createRegistry(RegistryFactory.java:58)
at org.eclipse.core.internal.registry.osgi.Activator.startRegistry(Activator.java:137)
at org.eclipse.core.internal.registry.osgi.Activator.start(Activator.java:56)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:460)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClass(MultiSourcePackage.java:31)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:254)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:399)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at org.eclipse.equinox.internal.app.Activator.start(Activator.java:55)
at org.eclipse.core.internal.runtime.PlatformActivator.startAppContainer(PlatformActivator.java:44)
at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:31)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1130)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.806
!MESSAGE Could not parse XML contribution for "org.eclipse.core.runtime//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
org.xml.sax.SAXException: Could not acquire XML parsing service.
at org.eclipse.core.internal.registry.ExtensionsParser.parseManifest(ExtensionsParser.java:392)
!ENTRY org.eclipse.osgi 4 0 2011-12-09 02:31:37.807
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.ServiceException: Exception in org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:148)
Caused by: javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
... 79 more
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.813
!MESSAGE Could not parse XML contribution for "com.justinmind.evc//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.840
!MESSAGE Could not parse XML contribution for "org.eclipse.ant.core//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.878
!MESSAGE Could not parse XML contribution for "org.eclipse.core.contenttype//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.893
!MESSAGE Could not parse XML contribution for "org.eclipse.core.expressions//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.895
!MESSAGE Could not parse XML contribution for "org.eclipse.core.filebuffers//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-12-09 02:31:37.898
!MESSAGE Could not parse XML contribution for "org.eclipse.core.filesystem//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
Comments (26)
How long should I reasonably wait to get support?
Is this typical of what I can expect if I purchase?
Sorry for the delay. Clients have a different support portal with a faster time of response.
We checked it and we believe it's something related with your java runtime machine. Could you reinstall java please?
Hello Victor,
As I stated in my original post of 4 days ago. Not only have I re-installed Java, when that didn't work, I also re-installed the entire OS - a process that took several hours.
The problem is isolated to my machine though because I have managed to install and run it on my wife's iMac. But on my 17" MBP , it simply refuses to start.
My current Java is 1.6.0_29.
Any more ideas?
Thanks...
Sorry for the delay on the answer but I was kind of in vacation. The error says Prototyper can't find a class that should come with the Java Runtime Machine. Could you open a console and write 'java -version' and do the same on your wife's computer please?
Hello Victor,
Ok, I have done as you asked. On my wife's machine, I get:
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03-384-10M3425)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02-384, mixed mode)
On my MBP, I get:
java version "1.6.0_29"
Java(TM) SE Runtime Environment (build 1.6.0_29-b11-402-10M3527)
Java HotSpot(TM) 64-Bit Server VM (build 20.4-b02-402, mixed mode)
As I said, I have re-installed the OS and Java several times. But I can't get it to work.
For the record, when I re-installed 10.6. I started at 10.6.0 and tried launching Prototyper then but it failed. I then updated 10.6.2 and tried again but it still failed. I did this with every dot release all the way to 10.6.8 but no luck. Along the way, Java also went through several revisions.
Thanks for the reply.
Could you try this please?
Go to the folder /System/Library/Java/Extensions and rename it
/System/Library/Java/Extensions.old. Open a console, go to the place you have prototyper and launch it with the -clean parameter. If that works you should be able to launch Prototyper in a normal way.
Hello Victor
Ok, all this Terminal stuff is a bit geeky for me but anyhow, I tried as you suggest. Let me know if this was correct or not:
I opened Terminal and then entered: open -a JustinmindPrototyper_4.4.1
That didn't work and I got the message: Unable to find application named 'JustinmindPrototyper_4.4.1'
I then tried:
open -a Prototyper
But these two failed.
Was that correct? I'm not sure what you meant by "-clean parameter". I Googled it but came up with nothing so I assumed you just meant -a
Anymore suggestions would be welcomed. I played with Protoyper on my wife's iMac and it's fantastic. Unfortunately running it on her machine isn't practical long term as it's in the kitchen! So, unless I can get this problem solved, I won't be purchasing which would be a shame as I haven't found anything even close to what Prototyper does.
Come one, Victor... what else have you got for me?
(I loved the story about you wife's computer in the kitchen, mine has one in the kitchen too ;))
I think the problem is how you try to launch prototyper from the console. You just have to write " JustinmindPrototyper -clean"
Alright, ran the command as you said and got:
-bash: JustinmindPrototyper: command not found
Sorry, I was wrong. First you have to write 'cd /applications' and hit the enter key. Then write 'open JustinmindPrototyper_4.4.1.app -clean'
Hmmmm.... tried that but got this:
open: invalid option -- c
Usage: open [-e] [-t] [-f] [-W] [-R] [-n] [-g] [-h] [-b ] [-a ] [filenames] [--args arguments]
Help: Open opens files from a shell.
By default, opens each file using the default application for that file.
If the file is in the form of a URL, the file will be opened as a URL.
Options:
-a Opens with the specified application.
-b Opens with the specified application bundle identifier.
-e Opens with TextEdit.
-t Opens with default text editor.
-f Reads input from standard input and opens with TextEdit.
-R, --reveal Selects in the Finder instead of opening.
-W, --wait-apps Blocks until the used applications are closed (even if they were already running).
--args All remaining arguments are passed in argv to the application's main() function instead of opened.
-n, --new Open a new instance of the application even if one is already running.
-g, --background Does not bring the application to the foreground.
-h, --header Searches header file locations for headers matching the given filenames, and opens them.
Just to be sure, I used: cd /applications
followed by: open JustinmindPrototyper_4.4.1.app -clean
Ahhhh... I saw all that text come up on the screen and I really thought we had something cookin'. But alas, no : (
Ok, lets try something different. Download this file http://justinmind.s3.amazonaws.com/Ju... . Then open the Applications folder with Finder. Locate the JustinmindPrototyper app, push the 'ctrl' key and click on the app. A menu will appear with different options, choose the one called 'Show package contents'. That will open another folder, open Contents/MacOS and replace the file JustinmindPrototyper.ini with the one you downloaded. Close the folder and launch Prototyper in a normal way.
No good I'm afraid. Still getting the "An error has occurred. See the log file" message.
And the error message it's the same right? You renamed the folder /System/Library/Java/Extensions? I presume so, well, this is the thing. For some reason there is a java library somewhere in your computer that is conflicting with the one in the Java Runtime Machine (I know this is highly techie). Maybe you have another software that created it. I'll try to find which is the conflicting library so you can do a search in your computer, meanwhile you can try to install the same Java as the one you have in the MBP http://support.apple.com/kb/DL1421
Yes, I tried launching with that directory renamed and as per the original name.
You are correct for sure. There is definitely a conflict or something missing. I have no idea what though.
That link is to Java 1.6.0_29 for Lion. I have 10.6.8 but I am running 1.6.0_29. I had already tried re-installing it anyhow.
If you have any Eureka moments as to the cause, please let me know. I am working on two large projects at the moment and every day I'm finding situations where I'd love to be getting my hands dirty with Prototyper. I'm really holding out for a solution here.
Thanks for the assistance so far.
Ok, lets try to find the library. The library is called jaxp.jar. Open a Finder window, then in the search box enter jaxp, it will return no results at all. In the search filters box just below the search box push the + button next to 'save'. Change the value in the drop down where it says 'kind' and choose 'other'. In the window that shows up check the 'File extension' check box and close. Then in the tiny box write 'jar'. Does it list any file?
You might be onto something now.
I tried a search as you suggested but got no results. Just to make sure, I tried it again with the option for visible & invisible items included.
Could you tell me the link you used to install Java? We are trying to reproduce your environment.
By link, do you mean where did I download it from?
If so, the process was:
I reinstalled OS X 10.6.0. I then updated via the Combo updates available for Apple. I went one dot release at a time and checked if I could launch Prototyper after installing each.
Once I got to 10.6.8, I ran Software Update from the Finder which advised there was an update to Java. When I checked the details, it pointed to this file:
http://support.apple.com/kb/DL1360
I then downloaded this update and ran it. I now have Java 1.6.0_29.
We still believe is something related to the jvm, maybe with the java 1.6. Could you try to follow these steps http://chxor.chxo.com/post/183013153/... to try to install java 1.5 instead?
Hello Victor,
I hope you had a great Christmas!
I haven't given up on this problem just yet. I got busy and then Christmas got in the way but I'm back at it now and really hoping I (we) can get this nailed. I'm now deep into a project that would be perfect for Prototyper and I soooooo want to use it!
I have followed the instructions at the link you provided buy alas, it hasn't fixed the problem. I now have both Java 1.6 & 1.5 running though which is pretty cool.
So, where to from here? I'd sure appreciate any more help or advice you can offer.
Thanks as always...
We are working to solve the problem. We will come back to you with a solution as soon as possible.
Bleh!
I just had to do a series of wireframes using OmniGraffle.
Now don't get me wrong. I have been using OmniGraffle for years and it's been great but now that I have had a taste of how I could be doing my wireframes, it seems soooo last century!
I want to divorce OmniGraffle. Please help me escape ; p
We've found how to fix this error. It looks like some software copy a set of corrupted libraries in this folder /System/Library/Java/Extensions . We don't know which software it is but at least we know how to make Prototyper work again. Follow these instructions:
- Open Finder and then open this folder
- Remove all the files inside that folder
- Reinstall Justinmind
This problem will be fixed from version 5.6
Meanwhile the issue could be solved following these instructions:
1. Close Prototyper if it's open.
2. Open Finder and go to the next folder: "your user folder"/Justinmind
3. Delete all the contents on this folder.
4. Go to Applications.
5. Right click on the Prototyper app and select the "Show Package Contents" option.
6. Go to /Contents/MacOs/ and open the file "Prototyper Pro.ini" with a text editor.
7. Add this line and the end of the file:
-Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl
8 .Launch the application again.
da6eb69dbf2e59dc9b90e945384bb690
I have already the same problem. I have downloaded de Justinmind 6.8 version, and cannot start the app. I have followed the instructions that appear above, reinstalling Java 1.5, removing contents of /System/Library/Java/Extensions/ folder, and I've seen that the line
is included in the justinmind.ini file in current 6.8 version.
What can I do? I can't try this software that appears to be so good.
(I wanted to include the starting error message, but it was too large...)
Thanks a lot in advance for your answer
