Prototyper Pro 5.6 error on startup on Mac OSX 10.9.4
Minoo Patel shared this problem 4 years ago
I checked the blogs and found this link for the exact same problem from a year ago:
I tried it and got past the license locking issue but ran into another error. The logs.log file contents are replicated here for your reference. Please advise on corrective action asap
thanks
============= Contents of logs.log file ============
[main ] [2014-07-15 19:11:08] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2014-07-15 19:11:09] INFO com.justinmind.metrics - {type=PC_INFO, hostname=minoomac.local, user=minoo.patel, install_id=110432161, license=00FFE348C152875842C706A73A9718B8, os=Mac OS X, os_version=10.9.4, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-462-11M4609, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2014-07-15 19:11:09] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2014-07-15 19:11:11] INFO com.justinmind.metrics - {type=CLOSED, use_time=1734}
[main ] [2014-07-15 19:11:11] ERROR com.justinmind.prototyper - com.justinmind.evc.igu.main.hi@7e28ebb4
java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3576)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:419)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1925)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1923)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1207)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
[main ] [2014-07-15 19:11:11] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2014-07-15 19:11:13] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2014-07-15 19:11:13] INFO com.justinmind.metrics - {type=PC_INFO, hostname=minoomac.local, user=minoo.patel, install_id=110432161, license=00FFE348C152875842C706A73A9718B8, os=Mac OS X, os_version=10.9.4, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-462-11M4609, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2014-07-15 19:11:13] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2014-07-15 19:11:14] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
Please send the following files to jim dot support at justinmind dot com:
[folder of the user]/justinmind/5.x/.metadata/.log
[folder of the user]/justinmind/5.x/.configuration/.log
[folder of the user]/justinmind/5.x/logs.log
These log files are inside a hidden folder so first you’ll need to enable hidden files on your Mac , is pretty simple you can follow the instructions from this link:
http://www.mikesel.info/show-hidden-f...
Also attach a screenshot of the error message you get.
Marc
