Prototyper not running anymore.
Leandro Monteiro shared this problem 7 years ago
Hello, I cant run Prototyper anymore. It returns an error on loading. Im using Lion. There's the error report:
Java was started but returned exit code=13
-Xms256m
-Xmx512m
-Xss2m
-XX:MaxPermSize=256m
-Dorg.eclipse.swt.internal.carbon.smallFonts
-Dfile.encoding=UTF-8
-Djava.class.path=/Applications/JustinmindPrototyper_4.0.1/JustinmindPrototyper.app/Contents/MacOS/../../../plugins/org.eclipse.equinox.launcher_1.2.0.v20110321-2120.jar1310496281368.tmp
-os macosx
-ws cocoa
-arch x86
-showsplash
-launcher /Applications/JustinmindPrototyper_4.0.1/JustinmindPrototyper.app/Contents/MacOS/JustinmindPrototyper
-name JustinmindPrototyper
--launcher.library /Applications/JustinmindPrototyper_4.0.1/JustinmindPrototyper.app/Contents/MacOS/../../../plugins/org.eclipse.equinox.launcher.cocoa.macosx_1.1.100.v20110321/eclipse_1406.so
-startup /Applications/JustinmindPrototyper_4.0.1/JustinmindPrototyper.app/Contents/MacOS/../../../plugins/org.eclipse.equinox.launcher_1.2.0.v20110321-2120.jar1310496281368.tmp
--launcher.overrideVmargs
-configuration @user.home/Justinmind/4.2.0/configuration
-data @user.home/Justinmind/4.2.0
-keyring /Users/pacceli/.eclipse_keyring
-showlocation
-vm /System/Library/Frameworks/JavaVM.framework
-vmargs
-Xms256m
-Xmx512m
-Xss2m
Comments (6)
Ok, we will look for the problem. As a workaround download Prototyper from our website and install it again.
Victor, I already did it. There's another workaround or it's something related to a Lion compatibility?
thanks!
Leandro
But your log says you are executing this file /Applications/JustinmindPrototyper_4.0.1/JustinmindPrototyper.app and that's not the last version.
Victor, sorry I already installed it but I was running the old version instead the new one trough spotlight. Solved! Tks
solved tks
Great!
