Prototyper crashes on open when users home folder on a server
Adam shared this problem 6 years ago
Is there a solution to run Prototyper on a computer where the users Home folder is kept on a server? The program crashes on open.
abcf3d8c209b9a8f3cf97d3f68f74fad
I think the problem is the folder macserver.leedhamcreative.com/users/creative5 must have write permissions to all users. You can try to edit the vm parameters configuration for Prototyper. Open a Finder window and go to Applications. Then ctrl+click on the Prototyper application and choose 'Show package contents'. Next open the folder contents/macos and edit the file named JustinmindPrototyper.ini. You can try to add the argument that the message suggest or remove the first four lines.
