Prototyper app crashes on first launch in OS X Lion
crlyn.re shared this problem 7 years ago
I've been trying to run Prototyper over the course of a few weeks and even when I completely uninstall and reinstall, run new software updates for my mac, try again when the moon is full, etc. ... I just plain can't get the program to run!
I'm attempting to use the trial download of 4.3.1 on OS X 10.7.1 (previously tried on 10.7.0 final release as well with same results). I do not have any software updates pending (including Java).
What happens is I install the trial successfully from the installer package off the website, and when I go to launch it, nothing happens! The app bounces in the dock like it's launching, but no loading screen or anything at all happens. And then no error message. There are also no log files at all showing up in the application's hidden resources folder.
Any ideas?
Carolyn
Comments (7)
My goodness... could you paste here the contents of these log files please or send them to jim dot support at justinmind dot com? That would really help us.
/Users//Justinmind/4.3.1/.metadata/.log
/Users//Justinmind/4.3.1/logs.log
/Users//Justinmind/4.3.1/configuration/*.log
The first one is a hidden folder. Follow these steps to see hidden folders in your mac http://www.mikesel.info/show-hidden-f...
Hi Victor, thank you for the quick response!
I just scoured the application's inner folders for a third time (and my hidden files are always visible), and there are absolutely no log files! I've also checked through the library and no folders or files for Justinmind appear anywhere. I'm assuming it's because the program has not ever actually run, which is very odd!
I did, however, find crash report logs for the application. Here are its contents:
Process: JustinmindPrototyper [35271]
Path: /Applications/JustinmindPrototyper_4.3.1.app/Contents/MacOS/JustinmindPrototyper
Identifier: com.justinmind.justinmindprototyper
Version: 4.3.1 (4.3)
Code Type: X86 (Native)
Parent Process: launchd [167]
Date/Time: 2011-09-14 18:15:04.387 -0400
OS Version: Mac OS X 10.7.1 (11B26)
Report Version: 9
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
objc[35271]: garbage collection is OFF
Java information:
Exception type: Internal Error (/SourceCache/JavaJDK16/JavaJDK16-383/hotspot/src/share/vm/utilities/exceptions.cpp, line 400)
# fatal error: ExceptionMark destructor expects no pending exceptions
Java VM: Java HotSpot(TM) Client VM (20.1-b02-383 mixed mode macosx-x86)
Current thread (0000000004a17000): JavaThread "main" [_thread_in_vm, id=-1399471424, stack(00000000bf800000,00000000c0000000)]
Stack: [00000000bf800000,00000000c0000000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j java.lang.ClassLoader.findBootstrapClass(Ljava/lang/String;)Ljava/lang/Class;+0
j java.lang.ClassLoader.findBootstrapClassOrNull(Ljava/lang/String;)Ljava/lang/Class;+12
j java.lang.ClassLoader.loadClass(Ljava/lang/String;Z)Ljava/lang/Class;+32
j java.lang.ClassLoader.loadClass(Ljava/lang/String;Z)Ljava/lang/Class;+23
j sun.misc.Launcher$AppClassLoader.loadClass(Ljava/lang/String;Z)Ljava/lang/Class;+41
j java.lang.ClassLoader.loadClass(Ljava/lang/String;)Ljava/lang/Class;+3
v ~StubRoutines::call_stub
Java Threads: ( => current thread )
0000000005247800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1314263040, stack(00000000b189f000,00000000b1a9f000)]
0000000005246800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1316368384, stack(00000000b169d000,00000000b189d000)]
0000000005245800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1318473728, stack(00000000b149b000,00000000b169b000)]
0000000004a3d400 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1320579072, stack(00000000b1299000,00000000b1499000)]
00000000062e4400 JavaThread "Finalizer" daemon [_thread_blocked, id=-1322684416, stack(00000000b1097000,00000000b1297000)]
0000000005a1a000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1324789760, stack(00000000b0e95000,00000000b1095000)]
=>0000000004a17000 JavaThread "main" [_thread_in_vm, id=-1399471424, stack(00000000bf800000,00000000c0000000)]
Other Threads:
00000000062e3800 VMThread [stack: 00000000b0d93000,00000000b0e93000] [id=-1326895104]
0000000005249000 WatcherThread [stack: 00000000b1aa1000,00000000b1ca1000] [id=-1312157696]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14784K, used 263K [0000000008810000, 0000000009810000, 000000000c810000)
eden space 13184K, 2% used [0000000008810000, 0000000008851ec8, 00000000094f0000)
from space 1600K, 0% used [00000000094f0000, 00000000094f0000, 0000000009680000)
to space 1600K, 0% used [0000000009680000, 0000000009680000, 0000000009810000)
concurrent mark-sweep generation total 245760K, used 0K [000000000c810000, 000000001b810000, 0000000028810000)
concurrent-mark-sweep perm gen total 12288K, used 1544K [0000000028810000, 0000000029410000, 0000000038810000)
Code Cache [0000000006801000, 0000000006872000, 0000000008801000)
total_blobs=116 nmethods=2 adapters=59 free_code_cache=33108928 largest_free_block=0
Virtual Machine Arguments:
JVM Args: -Xms256m -Xmx512m -Xss2m -XX:MaxPermSize=256m -Dorg.eclipse.swt.internal.carbon.smallFonts -Dfile.encoding=UTF-8
Java Command:
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 8192M, Free = 45M
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libjvm.dylib 0x02687a16 0x2400000 + 2652694
1 libjvm.dylib 0x0241b31d 0x2400000 + 111389
2 libjvm.dylib 0x02470bb7 0x2400000 + 461751
3 libjvm.dylib 0x02470b5b 0x2400000 + 461659
4 libjvm.dylib 0x0247070a 0x2400000 + 460554
5 libjvm.dylib 0x0246feca 0x2400000 + 458442
6 libjvm.dylib 0x0246eea9 0x2400000 + 454313
7 libjvm.dylib 0x024b8c8a 0x2400000 + 756874
8 libjvm.dylib 0x024b8bfe 0x2400000 + 756734
9 libjvmlinkage.dylib 0x007334a3 JVM_FindClassFromBootLoader + 51
10 libjava.jnilib 0x00779728 Java_java_lang_ClassLoader_findBootstrapClass + 167
11 ??? 0x0680b9d9 0 + 109099481
12 ??? 0x06803f97 0 + 109068183
13 ??? 0x06803f97 0 + 109068183
14 ??? 0x06803f97 0 + 109068183
15 ??? 0x06803f97 0 + 109068183
16 ??? 0x06803f97 0 + 109068183
17 ??? 0x06801374 0 + 109056884
18 libjvm.dylib 0x02496ab6 0x2400000 + 617142
19 libjvm.dylib 0x0249684e 0x2400000 + 616526
20 libjvm.dylib 0x024a2645 0x2400000 + 665157
21 libjvm.dylib 0x024b7cd0 0x2400000 + 752848
22 libjvm.dylib 0x02470126 0x2400000 + 459046
23 libjvm.dylib 0x0246eea9 0x2400000 + 454313
24 libjvm.dylib 0x0246e729 0x2400000 + 452393
25 libjvm.dylib 0x024a5b9e 0x2400000 + 678814
26 libjvm.dylib 0x024a5ab4 0x2400000 + 678580
27 eclipse_1406.so 0x000e3160 startJavaJNI + 490
28 eclipse_1406.so 0x000e2312 startJavaVM + 120
29 eclipse_1406.so 0x000e07c7 run + 4976
30 com.justinmind.justinmindprototyper0x000030dc original_main + 1914
31 com.justinmind.justinmindprototyper0x000037c9 main + 1518
32 com.justinmind.justinmindprototyper0x0000282b _start + 209
33 com.justinmind.justinmindprototyper0x00002759 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x94d3c90a kevent + 10
1 libdispatch.dylib 0x94d44ccc _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x94d4371b _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x94d3c02e __workq_kernreturn + 10
1 libsystem_c.dylib 0x95033ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x950356fe start_wqthread + 30
Thread 3:
Thread 4:: Java: Exception Handler Thread
0 libsystem_kernel.dylib 0x94d39c22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x94d391f6 mach_msg + 70
2 libsystem_kernel.dylib 0x94d39835 mach_msg_server + 699
3 libjvm.dylib 0x024153f9 0x2400000 + 87033
4 libjvm.dylib 0x02415290 0x2400000 + 86672
5 libjvm.dylib 0x0241403d 0x2400000 + 81981
6 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
7 libsystem_c.dylib 0x950356de thread_start + 34
Thread 5:: Java: Gang worker#0 (Parallel GC Threads)
2 libjvm.dylib 0x02686f31 0x2400000 + 2649905
3 libjvm.dylib 0x024143f6 0x2400000 + 82934
4 libjvm.dylib 0x0267b149 0x2400000 + 2601289
5 libjvm.dylib 0x0267b218 0x2400000 + 2601496
6 libjvm.dylib 0x02413f6d 0x2400000 + 81773
7 libjvm.dylib 0x02428fc6 0x2400000 + 167878
8 libjvm.dylib 0x0241403d 0x2400000 + 81981
9 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
10 libsystem_c.dylib 0x950356de thread_start + 34
Thread 6:: Java: Gang worker#1 (Parallel GC Threads)
Thread 7:: Java: Gang worker#2 (Parallel GC Threads)
Thread 8:: Java: Gang worker#3 (Parallel GC Threads)
Thread 9:: Java: Concurrent Mark-Sweep GC Thread
2 libjvm.dylib 0x02687001 0x2400000 + 2650113
3 libjvm.dylib 0x026873a4 0x2400000 + 2651044
4 libjvm.dylib 0x0267b163 0x2400000 + 2601315
7 libjvm.dylib 0x024c2b01 0x2400000 + 797441
8 libjvm.dylib 0x024c2a69 0x2400000 + 797289
9 libjvm.dylib 0x0242f07b 0x2400000 + 192635
10 libjvm.dylib 0x0241403d 0x2400000 + 81981
11 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
12 libsystem_c.dylib 0x950356de thread_start + 34
Thread 10:: Java: VM Thread
7 libjvm.dylib 0x02495870 0x2400000 + 612464
8 libjvm.dylib 0x02495520 0x2400000 + 611616
9 libjvm.dylib 0x0241403d 0x2400000 + 81981
10 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
11 libsystem_c.dylib 0x950356de thread_start + 34
Thread 11:: Java: Reference Handler
4 libjvm.dylib 0x026832f4 0x2400000 + 2634484
5 libjvm.dylib 0x026c255f 0x2400000 + 2893151
6 libjvm.dylib 0x024a280e JVM_MonitorWait + 196
7 libjvmlinkage.dylib 0x00731dd5 JVM_MonitorWait + 69
8 ??? 0x0680b9d9 0 + 109099481
9 ??? 0x06803e31 0 + 109067825
10 ??? 0x06803e31 0 + 109067825
11 ??? 0x06801374 0 + 109056884
12 libjvm.dylib 0x02496ab6 0x2400000 + 617142
13 libjvm.dylib 0x0249684e 0x2400000 + 616526
14 libjvm.dylib 0x024a2645 0x2400000 + 665157
15 libjvm.dylib 0x024a254a 0x2400000 + 664906
16 libjvm.dylib 0x024a24d8 0x2400000 + 664792
17 libjvm.dylib 0x024a234c 0x2400000 + 664396
18 libjvm.dylib 0x024a21ab 0x2400000 + 663979
19 libjvm.dylib 0x0241403d 0x2400000 + 81981
20 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
21 libsystem_c.dylib 0x950356de thread_start + 34
Thread 12:: Java: Finalizer
10 ??? 0x06803f97 0 + 109068183
11 ??? 0x06803f97 0 + 109068183
12 ??? 0x06801374 0 + 109056884
13 libjvm.dylib 0x02496ab6 0x2400000 + 617142
14 libjvm.dylib 0x0249684e 0x2400000 + 616526
15 libjvm.dylib 0x024a2645 0x2400000 + 665157
16 libjvm.dylib 0x024a254a 0x2400000 + 664906
17 libjvm.dylib 0x024a24d8 0x2400000 + 664792
18 libjvm.dylib 0x024a234c 0x2400000 + 664396
19 libjvm.dylib 0x024a21ab 0x2400000 + 663979
20 libjvm.dylib 0x0241403d 0x2400000 + 81981
21 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
22 libsystem_c.dylib 0x950356de thread_start + 34
Thread 13:: Java: Surrogate Locker Thread (Concurrent GC)
6 libjvm.dylib 0x02413eb4 0x2400000 + 81588
7 libjvm.dylib 0x024b241b 0x2400000 + 730139
Thread 14:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x94d39c5e semaphore_wait_trap + 10
1 libjvm.dylib 0x024b2c4d 0x2400000 + 732237
2 libjvm.dylib 0x024b2638 0x2400000 + 730680
3 libjvm.dylib 0x024a234c 0x2400000 + 664396
4 libjvm.dylib 0x024a21ab 0x2400000 + 663979
Thread 15:: Java: C1 CompilerThread0
7 libjvm.dylib 0x024b9774 0x2400000 + 759668
8 libjvm.dylib 0x024b3dac 0x2400000 + 736684
9 libjvm.dylib 0x024a234c 0x2400000 + 664396
10 libjvm.dylib 0x024a21ab 0x2400000 + 663979
11 libjvm.dylib 0x0241403d 0x2400000 + 81981
12 libsystem_c.dylib 0x95031ed9 _pthread_start + 335
13 libsystem_c.dylib 0x950356de thread_start + 34
Thread 16:: Java: Low Memory Detector
7 libjvm.dylib 0x024b5738 0x2400000 + 743224
Thread 17:: Java: VM Periodic Task Thread
3 libjvm.dylib 0x02687593 0x2400000 + 2651539
4 libjvm.dylib 0x024b7830 0x2400000 + 751664
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0274b482 ebx: 0x04a17960 ecx: 0x00012068 edx: 0x00001b00
edi: 0xbfffe900 esi: 0x026f28ea ebp: 0xbfffe878 esp: 0xbfffe878
ss: 0x00000023 efl: 0x00000286 eip: 0x02687a16 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x0524c000
Logical CPU: 1
Binary Images:
0x1000 - 0x4fff +com.justinmind.justinmindprototyper (4.3.1 - 4.3) /Applications/JustinmindPrototyper_4.3.1.app/Contents/MacOS/JustinmindPrototyper
0xdd000 - 0xe5fff +eclipse_1406.so (??? - ???) /Applications/JustinmindPrototyper_4.3.1.app/Contents/Resources/Java/plugins/org.eclipse.equinox.launcher.cocoa.macosx_1.1.100.v20110321/eclipse_1406.so
0x71a000 - 0x71effd com.apple.JavaVM (14.0.3 - 14.0.3) /System/Library/Frameworks/JavaVM.framework/JavaVM
0x726000 - 0x72afff JavaLaunching (??? - ???) /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x731000 - 0x738ffb libjvmlinkage.dylib (??? - ???) /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
0x759000 - 0x760fff libverify.dylib (1.0 - 1.0) /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
0x765000 - 0x76dfff JavaNativeFoundation (??? - ???) /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x776000 - 0x793fff libjava.jnilib (??? - ???) /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
0x7af000 - 0x7bbfff libzip.jnilib (??? - ???) /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
0x2400000 - 0x2737fee libjvm.dylib (??? - ???) /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm.dylib
0x8fed4000 - 0x8ff069c7 dyld (195.5 - ???) /usr/lib/dyld
0x90016000 - 0x9004cfff com.apple.DebugSymbols (2.1 - 85) /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9017f000 - 0x90482ff7 com.apple.Foundation (6.7 - 833.1) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90483000 - 0x904b3ff7 libsystem_info.dylib (??? - ???) /usr/lib/system/libsystem_info.dylib
0x904b4000 - 0x907b4fff com.apple.CoreServices.CarbonCore (960.13 - 960.13) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x908ca000 - 0x909baff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) /usr/lib/libiconv.2.dylib
0x90d67000 - 0x90e90ff9 com.apple.CFNetwork (520.0.13 - 520.0.13) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90e91000 - 0x90ed8fff com.apple.SystemConfiguration (1.11 - 1.11) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90f44000 - 0x90f4bff5 libsystem_dnssd.dylib (??? - ???) /usr/lib/system/libsystem_dnssd.dylib
0x90f4c000 - 0x90f4dff5 libremovefile.dylib (21.0.0 - compatibility 1.0.0) /usr/lib/system/libremovefile.dylib
0x90f4e000 - 0x90f70ffe com.apple.framework.familycontrols (3.0 - 300) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x911ac000 - 0x911bdfff libbsm.0.dylib (??? - ???) /usr/lib/libbsm.0.dylib
0x911be000 - 0x9122cfff com.apple.Heimdal (2.1 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x91304000 - 0x91308ffa libcache.dylib (47.0.0 - compatibility 1.0.0) /usr/lib/system/libcache.dylib
0x916c2000 - 0x916dffff libresolv.9.dylib (46.0.0 - compatibility 1.0.0) /usr/lib/libresolv.9.dylib
0x916e0000 - 0x9173cff3 com.apple.Symbolication (1.2 - 83.1) /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x91746000 - 0x917cdfff com.apple.print.framework.PrintCore (7.0 - 366) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x917dd000 - 0x917e1fff libGIF.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x917e2000 - 0x917f0fff libz.1.dylib (1.2.5 - compatibility 1.0.0) /usr/lib/libz.1.dylib
0x91ab4000 - 0x91ad9ff9 libJPEG.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b59000 - 0x91b61ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) /usr/lib/system/libunwind.dylib
0x91b62000 - 0x91b64ffb libRadiance.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x92283000 - 0x92685ff6 libLAPACK.dylib (??? - ???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92686000 - 0x9268efff com.apple.DiskArbitration (2.4 - 2.4) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9268f000 - 0x92690fff com.apple.TrustEvaluationAgent (2.0 - 1) /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x92691000 - 0x926cdfff libcups.2.dylib (2.9.0 - compatibility 2.0.0) /usr/lib/libcups.2.dylib
0x926ce000 - 0x927b6fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x927c5000 - 0x927c6ff7 libsystem_sandbox.dylib (??? - ???) /usr/lib/system/libsystem_sandbox.dylib
0x927f5000 - 0x927f8ffd libCoreVMClient.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x927fb000 - 0x92896ff3 com.apple.ink.framework (1.3.2 - 110) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92897000 - 0x928fefff libc++.1.dylib (19.0.0 - compatibility 1.0.0) /usr/lib/libc++.1.dylib
0x9296e000 - 0x9296fff0 libunc.dylib (24.0.0 - compatibility 1.0.0) /usr/lib/system/libunc.dylib
0x92970000 - 0x92a30ff3 com.apple.ColorSync (4.7.0 - 4.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x92a5d000 - 0x92aa0ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) /usr/lib/system/libcommonCrypto.dylib
0x92aa1000 - 0x92ab7ffe libxpc.dylib (77.16.0 - compatibility 1.0.0) /usr/lib/system/libxpc.dylib
0x92ab8000 - 0x9311d65b com.apple.CoreGraphics (1.600.0 - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x93244000 - 0x9325efff com.apple.Kerberos (1.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9327a000 - 0x9327aff2 com.apple.CoreServices (53 - 53) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93568000 - 0x93573ffb com.apple.speech.recognition.framework (4.0.19 - 4.0.19) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93578000 - 0x939cdfff FaceCoreLight (1.4.2 - compatibility 1.0.0) /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x939ce000 - 0x939d1ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) /usr/lib/system/libcompiler_rt.dylib
0x93a24000 - 0x93ab8ff7 com.apple.LaunchServices (480.19 - 480.19) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93ab9000 - 0x93ac3ff2 com.apple.audio.SoundManager (3.9.4 - 3.9.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93ac4000 - 0x93aecff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) /usr/lib/libxslt.1.dylib
0x93aed000 - 0x93b79ff7 com.apple.CoreText (4.0.0 - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x93c15000 - 0x93cd5fff com.apple.CoreServices.OSServices (478.25.1 - 478.25.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93cd6000 - 0x93ce9ff9 com.apple.MultitouchSupport.framework (220.62 - 220.62) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93cea000 - 0x93cecff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) /usr/lib/system/libdyld.dylib
0x93ced000 - 0x93cf5ff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) /usr/lib/system/libcopyfile.dylib
0x93cf6000 - 0x93dc5ffb com.apple.ImageIO.framework (3.1.0 - 3.1.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x93eb7000 - 0x9493cffe com.apple.AppKit (6.7 - 1138) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94b3c000 - 0x94b3dfff libDiagnosticMessagesClient.dylib (??? - ???) /usr/lib/libDiagnosticMessagesClient.dylib
0x94b62000 - 0x94c38a5b libobjc.A.dylib (228.0.0 - compatibility 1.0.0) /usr/lib/libobjc.A.dylib
0x94c39000 - 0x94c67fe7 libSystem.B.dylib (159.0.0 - compatibility 1.0.0) /usr/lib/libSystem.B.dylib
0x94c68000 - 0x94c8aff1 com.apple.PerformanceAnalysis (1.10 - 10) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x94c8b000 - 0x94d22ff3 com.apple.securityfoundation (5.0 - 55005) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94d23000 - 0x94d41ff7 libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) /usr/lib/system/libsystem_kernel.dylib
0x94d42000 - 0x94d50fff libdispatch.dylib (187.5.0 - compatibility 1.0.0) /usr/lib/system/libdispatch.dylib
0x94df7000 - 0x94e72ffb com.apple.ApplicationServices.ATS (5.0 - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x94e73000 - 0x94fd4ffb com.apple.QuartzCore (1.7 - 269.0) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94fd5000 - 0x950a0fff libsystem_c.dylib (763.11.0 - compatibility 1.0.0) /usr/lib/system/libsystem_c.dylib
0x950a1000 - 0x9512bffb com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x951bf000 - 0x9521fffb com.apple.audio.CoreAudio (4.0.0 - 4.0.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9527f000 - 0x9539ffec com.apple.vImage (5.0 - 5.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x953a0000 - 0x9542dfe7 libvMisc.dylib (325.3.0 - compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x95e51000 - 0x95e5efff libGL.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95e66000 - 0x95e67fff liblangid.dylib (??? - ???) /usr/lib/liblangid.dylib
0x95e68000 - 0x95e68fff com.apple.Accelerate (1.7 - Accelerate 1.7) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95e69000 - 0x95e88fff com.apple.RemoteViewServices (1.0 - 1) /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x95ee7000 - 0x95ff2ffb com.apple.DesktopServices (1.6.0 - 1.6.0) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x95ff3000 - 0x96043ff4 libTIFF.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96044000 - 0x96044fff com.apple.audio.units.AudioUnit (1.7 - 1.7) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x96045000 - 0x962f6ff7 com.apple.security (7.0 - 55010) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x962f7000 - 0x96568ffb com.apple.CoreImage (7.77 - 1.0.1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x96569000 - 0x9656affd libCVMSPluginSupport.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x965d7000 - 0x96630ff3 com.apple.coreui (0.3 - 162) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9761e000 - 0x97654ff7 com.apple.AE (527.6 - 527.6) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x97ac1000 - 0x97ac6ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) /usr/lib/system/libmacho.dylib
0x97ac7000 - 0x97b2bfff com.apple.framework.IOKit (2.0 - ???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x97b2d000 - 0x97b2dfff com.apple.vecLib (3.7 - vecLib 3.7) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97b2e000 - 0x97b98ff3 com.apple.CoreSymbolication (2.1 - 66) /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x97b99000 - 0x97b99ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) /usr/lib/system/libkeymgr.dylib
0x97b9a000 - 0x97b9fffd libGFXShared.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x97baf000 - 0x97bb0ff7 libquarantine.dylib (36.0.0 - compatibility 1.0.0) /usr/lib/system/libquarantine.dylib
0x97bb1000 - 0x97bbcffc com.apple.NetAuth (1.0 - 3.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x97f2c000 - 0x97f6cff7 libauto.dylib (??? - ???) /usr/lib/libauto.dylib
0x98420000 - 0x9842efff com.apple.opengl (1.7.4 - 1.7.4) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x98769000 - 0x98c45ff6 libBLAS.dylib (??? - ???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9919d000 - 0x99351ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) /usr/lib/libicucore.A.dylib
0x993f5000 - 0x9941effe com.apple.opencl (1.50.62 - 1.50.62) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9941f000 - 0x99425ffd com.apple.CommerceCore (1.0 - 17) /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9954e000 - 0x9959fff9 com.apple.ScalableUserInterface (1.0 - 1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x995a0000 - 0x995a4ff7 com.apple.OpenDirectory (10.7 - 144) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x995a5000 - 0x99649fff com.apple.QD (3.12 - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x99686000 - 0x996a9fff com.apple.CoreVideo (1.7 - 70.0) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x996aa000 - 0x996fafff libFontRegistry.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x996fb000 - 0x99726fff com.apple.GSS (2.1 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x99748000 - 0x997a0fff com.apple.HIServices (1.9 - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x997a1000 - 0x9993aff7 com.apple.CoreData (103 - 358.4) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x99947000 - 0x99948fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) /usr/lib/system/libsystem_blocks.dylib
0x99954000 - 0x99954fff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) /usr/lib/system/libdnsinfo.dylib
0x9998c000 - 0x9998fffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) /usr/lib/libpam.2.dylib
0x99990000 - 0x99a05fff com.apple.Metadata (10.7.0 - 627.9) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x99b35000 - 0x99b3dff3 liblaunch.dylib (392.18.0 - compatibility 1.0.0) /usr/lib/system/liblaunch.dylib
0x99b3e000 - 0x99b53fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9ace4000 - 0x9ad46ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) /usr/lib/libstdc++.6.dylib
0x9ad74000 - 0x9ae6cff7 libFontParser.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9ae6d000 - 0x9b043fef com.apple.CoreFoundation (6.7 - 635) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9b078000 - 0x9b0a6ffb com.apple.DictionaryServices (1.2 - 158) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9b0a7000 - 0x9b0b7fff com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9b0b8000 - 0x9b0b8ff0 com.apple.ApplicationServices (41 - 41) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9b19c000 - 0x9b2abff7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) /usr/lib/libsqlite3.dylib
0x9b2f0000 - 0x9b3d3ff7 libcrypto.0.9.8.dylib (0.9.8 - compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
0x9b4d0000 - 0x9b4d4ffd IOSurface (??? - ???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9b4d5000 - 0x9b4d5fff com.apple.Cocoa (6.6 - ???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9b4d6000 - 0x9b4e1fff libkxld.dylib (??? - ???) /usr/lib/system/libkxld.dylib
0x9b55b000 - 0x9b5bdffb com.apple.datadetectorscore (3.0 - 179.3) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x9b875000 - 0x9bbb4ff3 com.apple.HIToolbox (1.7 - ???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9bbc6000 - 0x9bbcffff libc++abi.dylib (14.0.0 - compatibility 1.0.0) /usr/lib/libc++abi.dylib
0x9bbd0000 - 0x9bbecff5 com.apple.GenerationalStorage (1.0 - 124) /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9bbed000 - 0x9bbfdff7 libCRFSuite.dylib (??? - ???) /usr/lib/libCRFSuite.dylib
0x9bbff000 - 0x9bc02ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) /usr/lib/system/libmathCommon.A.dylib
0x9bc03000 - 0x9bc17ff7 com.apple.CFOpenDirectory (10.7 - 144) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9bc18000 - 0x9bd6affb com.apple.audio.toolbox.AudioToolbox (1.7 - 1.7) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9bd6b000 - 0x9bd72fff libnotify.dylib (80.0.0 - compatibility 1.0.0) /usr/lib/system/libnotify.dylib
0x9be16000 - 0x9be16fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9be17000 - 0x9be60ff7 libGLU.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9beeb000 - 0x9bf27ffa libGLImage.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9c264000 - 0x9c26bffd com.apple.NetFS (4.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9c2ca000 - 0x9c2ceff3 libsystem_network.dylib (??? - ???) /usr/lib/system/libsystem_network.dylib
0x9c2cf000 - 0x9c334ff7 libvDSP.dylib (325.3.0 - compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9c335000 - 0x9c33eff3 com.apple.CommonAuth (2.1 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9c33f000 - 0x9c358fff libPng.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9c63c000 - 0x9c74dff7 libJP2.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 38518
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=129.4M resident=158.3M(122%) swapped_out_or_unallocated=16777216.0T(13595362459648%)
Writable regions: Total=945.8M written=5056K(1%) resident=5996K(1%) swapped_out=0K(0%) unallocated=939.9M(99%)
REGION TYPE VIRTUAL
CG shared images 128K
Java 291.4M
Java (reserved) 538.3M reserved VM address space (unallocated)
MALLOC 78.6M
MALLOC guard page 64K
Mach message 8K
Stack 92.6M
VM_ALLOCATE 460K
__CI_BITMAP 80K
__DATA 7732K
__DATA/__OBJC 124K
__IMAGE 1256K
__IMPORT 12K
__LINKEDIT 41.6M
__OBJC 1444K
__OBJC/__DATA 12K
__PAGEZERO 4K
__TEXT 87.8M
__UNICODE 544K
mapped file 132.8M
shared memory 312K
shared pmap 10.5M
TOTAL 1.3G
TOTAL, minus reserved VM space 747.3M
Thanks for your help Carolyn. It's really appreciated. We have been doing some research and we believe there is a problem with the java runtime machine. There are similar bugs reported for other products as well with the new OSX Lion. Sadly in our "Lions" works well and we can't reproduce the error. Would you be so kind to help us a bit more? Could you try to install java again from here : http://blogs.tech-recipes.com/davak/2... and try with a different boot order? Finally one question: have you upgrade from Snow Leopard or is your Lion a fresh installation?
Thanks Victor--downloading and re-installing Flash worked great!
I believe I'm using a clean install of Lion--it's been a while, but I'm 90% sure I chose not to just upgrade and went with a fresh installation instead.
Problem solved. Thank you!!
You mean 're-installing Java' don't you? I'm glad to know that is working now. Let me know what you think about it when you try it.
