Prototyper 5 fails to run
Ryan Pream shared this problem 6 years ago
Everytime I go to run version 5 (after the first run that seemed to copy files successfully) I get a error message about a licences became corrupted, it has been removed, please restart prototyper. Does this everytime. Here is the output from the log file
[main ] [2012-10-17 05:07:34] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2012-10-17 05:07:36] ERROR com.justinmind.prototyper - com.justinmind.evc.igu.main.yh@49af7e68
java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3576)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:419)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1925)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1923)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1207)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
[main ] [2012-10-17 05:07:36] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2012-10-17 05:07:38] INFO com.justinmind.prototyper - START Justinmind Prototyper
If you are in a Windows computer please delete this folder:
c:ProgramData.license
If you are in a Mac computer:
Open the terminal and type: "defaults write com.apple.Finder AppleShowAllFiles YES" in order to view the invisible files and locate the "/etc/JustinmindPrototyper/.license" folder. Delete the that folder and try Prototyper again.
