Prototype within a iPhone Frame
barl0w shared this problem 5 years ago
With the update to 5.5.0, when I Simulate, there is an iPhone 5 phone frame, and inside another iPhone 5 with my app inside it.
The two don't quite line-up, and so it makes the simulation look really weird. Why is this popping up with the new update, and is there a way that I can correct it?
8263d7f903d0eac9879d112ce02459d8
Comments (4)
Because in the previous version the prototypes included the image of an iPhone, but in the new one you can have an emulator instead. The image is defined in the template so I'm afraid you'll need to download Pro edition, open your prototype, go to Templates and remove the image of the iPhone from there. Then you have to open all your screens and move all the content to the 0,0 position.
I have pro. when I go to templates in my project in the ide upper right and try to remove the template I get an error message that says I can't remove it. Any other suggestions?
You don't need to remove the entire template, you just need to select it and then, in the canvas, remove the image of the iPhone 5.
That works. Thanks.
