Prototype extremely slow
Shane shared this problem 5 years ago
What can I do to speed things up? Prototyper is painfully slow. Currently using trial version, filesize under 8mb, not really many images. The delay is far too long to use the program effectively. 5+ second delay for every move, resize, changing tabs, everything. Please help
Was this ever solved? I'm considering Justinmind and having no response is worrisome.
Things that can affect performance are: number of elements per screen, high-resolution images (even if they are resized to a smaller size) and Data Grids showing Data Masters with large amount of instances (or Data Grids inside other Data Grids). A way to increase performance would be to split your prototype file into different prototypes. Also try increasing the memory used by Justinmind Prototyper. In order to do that change, go to your Justinmind installation folder and open the file 'JustinmindPrototyper.ini' with a text editor. Write 1024m next to the parameter -xmx, so it reads -xmx1024m (instead of -xmx512m).
