Downloaded the trial and received an error asking me to check the log.
See the log file
/Applications/JustinmindPrototyper_4.1.1.app/Contents/Resources/Java/configuration/1299083240856.log.
And heres what in the log:
!SESSION 2011-03-03 00:27:20.562 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_22
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/Kiat/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.1.1.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86 -keyring /Users/Kiat/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.1.1.app/Contents/Resources/Java
!ENTRY org.eclipse.equinox.app 0 0 2011-03-03 00:27:21.425
!MESSAGE Product com.justinmind.evc.EVC could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-03-03 00:27:21.503
!MESSAGE Application error
!STACK 1
org.osgi.service.application.ApplicationException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:256)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:610)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:565)
at org.eclipse.equinox.launcher.Main.run(Main.java:1362)
That's the entire log?
Yes, thats the entire log pasted from where they mention.
Mmm, could you paste here the content of the folder Justinmind Prototyper.app --> Contents --> Resources --> Java --> Plugins please?
com.ibm.icu_4.0.1.v20090822.jar
com.justinmind.evc_4.1.1.jar
javax.servlet_2.5.0.v200806031605.jar
javax.servlet.jsp_2.0.0.v200806031607.jar
org.apache.batik.bridge_1.6.0.v200805290154.jar
org.apache.batik.css_1.6.0.v200805290154.jar
org.apache.batik.dom_1.6.0.v200805290154.jar
org.apache.batik.dom.svg_1.6.0.v200805290154.jar
org.apache.batik.ext.awt_1.6.0.v200805290154.jar
org.apache.batik.parser_1.6.0.v200805290154.jar
org.apache.batik.pdf_1.6.0.v200806031500.jar
org.apache.batik.svggen_1.6.0.v200805290154.jar
org.apache.batik.transcoder_1.6.0.v200805290154.jar
org.apache.batik.util_1.6.0.v200805290154.jar
org.apache.batik.util.gui_1.6.0.v200805290154.jar
org.apache.batik.xml_1.6.0.v200805290154.jar
org.apache.commons.el_1.0.0.v200806031608.jar
org.apache.commons.logging_1.0.4.v200904062259.jar
org.apache.jasper_5.5.17.v200903231320.jar
org.apache.lucene_1.9.1.v20080530-1600.jar
org.apache.lucene.analysis_1.9.1.v20080530-1600.jar
org.eclipse.ant.core_3.2.100.v20090817.jar
org.eclipse.compare.core_3.5.100.I20090714-0800.jar
org.eclipse.core.commands_3.5.0.I20090525-2000.jar
org.eclipse.core.contenttype_3.4.100.v20090831.jar
org.eclipse.core.databinding_1.3.0.I20090825-0800.jar
org.eclipse.core.databinding.beans_1.2.0.I20090525-2000.jar
org.eclipse.core.databinding.observable_1.3.0.I20090901-0800.jar
org.eclipse.core.databinding.property_1.2.100.I20090825-0800.jar
org.eclipse.core.expressions_3.4.100.v20090429-1800.jar
org.eclipse.core.filebuffers_3.5.0.v20090914-0800.jar
org.eclipse.core.filesystem_1.3.0.v20090831.jar
org.eclipse.core.jobs_3.4.100.v20090429-1800.jar
org.eclipse.core.net_1.2.100.I20090714-0800.jar
org.eclipse.core.resources_3.5.100.v20090911.jar
org.eclipse.core.runtime_3.5.100.v20090911.jar
org.eclipse.core.runtime.compatibility_3.2.0.v20090413.jar
org.eclipse.core.runtime.compatibility.auth_3.2.100.v20090413.jar
org.eclipse.core.variables_3.2.300.v20090911.jar
org.eclipse.draw2d_3.6.0.v20090813-1401.jar
org.eclipse.emf.common_2.6.0.v200909211047.jar
org.eclipse.emf.common.ui_2.5.0.v200909211047.jar
org.eclipse.emf.ecore_2.6.0.v200909211047.jar
org.eclipse.emf.ecore.change_2.5.0.v200909211047.jar
org.eclipse.emf.ecore.change.edit_2.5.0.v200909211047.jar
org.eclipse.emf.ecore.edit_2.6.0.v200909211047.jar
org.eclipse.emf.ecore.xmi_2.5.0.v200909211047.jar
org.eclipse.emf.edit_2.6.0.v200909211047.jar
org.eclipse.emf.edit.ui_2.6.0.v200909211047.jar
org.eclipse.emf.transaction_1.3.0.v200902010221.jar
org.eclipse.emf.validation_1.3.0.v200901271722.jar
org.eclipse.emf.workspace_1.4.0.v20100224-1706.jar
org.eclipse.equinox.app_1.2.0.v20090520-1800.jar
org.eclipse.equinox.common_3.5.100.v20090817.jar
org.eclipse.equinox.ds_1.1.100.v20090824.jar
org.eclipse.equinox.event_1.1.100.v20090911.jar
org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar
org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar
org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar
org.eclipse.equinox.jsp.jasper_1.0.200.v20090520-1800.jar
org.eclipse.equinox.jsp.jasper.registry_1.0.100.v20090520-1800.jar
org.eclipse.equinox.launcher_1.0.300.v20090911.jar
org.eclipse.equinox.launcher.cocoa.macosx_1.0.100.v20090908
org.eclipse.equinox.preferences_3.2.300.v20090520-1800.jar
org.eclipse.equinox.registry_3.5.0.v20090911.jar
org.eclipse.equinox.security_1.0.100.v20090520-1800.jar
org.eclipse.equinox.simpleconfigurator_1.0.200.v20090831.jar
org.eclipse.equinox.util_1.0.100.v20090520-1800.jar
org.eclipse.gef_3.6.0.v20090910-2050.jar
org.eclipse.gmf_1.2.0.v20090615-0700.jar
org.eclipse.gmf.runtime.common.core_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.common.ui_1.3.0.v20090722-1925.jar
org.eclipse.gmf.runtime.common.ui.action_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.common.ui.printing_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.common.ui.services_1.2.0.v20090929-1734.jar
org.eclipse.gmf.runtime.common.ui.services.action_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.common.ui.services.dnd_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.common.ui.services.properties_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.diagram.core_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.diagram.ui_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.diagram.ui.actions_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.diagram.ui.dnd_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.diagram.ui.geoshapes_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.diagram.ui.printing_1.3.0.v20090708-1925.jar
org.eclipse.gmf.runtime.diagram.ui.printing.render_1.3.0.v20090708-1925.jar
org.eclipse.gmf.runtime.diagram.ui.properties_1.3.0.v20090729-1925.jar
org.eclipse.gmf.runtime.diagram.ui.providers_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.diagram.ui.render_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.diagram.ui.resources.editor_1.2.0.v20090526-1925.jar
org.eclipse.gmf.runtime.draw2d.ui_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.draw2d.ui.render_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.draw2d.ui.render.awt_1.3.0.v20090929-1734.jar
org.eclipse.gmf.runtime.emf.clipboard.core_1.2.0.v20090929-1734.jar
org.eclipse.gmf.runtime.emf.commands.core_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.emf.core_1.2.0.v20090422-1925.jar
org.eclipse.gmf.runtime.emf.type.core_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.emf.type.ui_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.emf.ui_1.2.0.v20090403-1720.jar
org.eclipse.gmf.runtime.emf.ui.properties_1.2.0.v20090501-1750.jar
org.eclipse.gmf.runtime.gef.ui_1.2.0.v20090520-1343.jar
org.eclipse.gmf.runtime.notation_1.2.0.v20090521-1925.jar
org.eclipse.help_3.5.0.v20090729.jar
org.eclipse.help.appserver_3.1.400.v20090429_1800.jar
org.eclipse.help.base_3.4.100.v200909170100.jar
org.eclipse.help.ui_3.5.0.v20090904.jar
org.eclipse.help.webapp_3.5.0.v20090911.jar
org.eclipse.jface_3.5.100.I20090914-0830.jar
org.eclipse.jface.databinding_1.3.100.I20090825-0800.jar
org.eclipse.jface.text_3.5.100.v20090914-0800.jar
org.eclipse.osgi_3.6.0.v20090914.jar
org.eclipse.osgi.services_3.2.0.v20090520-1800.jar
org.eclipse.rcp_3.5.0.v200909170100.jar
org.eclipse.swt_3.6.0.v3611d.jar
org.eclipse.swt.cocoa.macosx_3.6.0.v3611d.jar
org.eclipse.team.core_3.5.0.I20090916-0800.jar
org.eclipse.text_3.5.0.v20090914-0800.jar
org.eclipse.ui_3.6.0.I20090916-1600.jar
org.eclipse.ui.cocoa_1.0.0.I20090525-2000.jar
org.eclipse.ui.console_3.5.0.v20090907.jar
org.eclipse.ui.forms_3.4.100.v20090729.jar
org.eclipse.ui.intro_3.3.100.v20090720.jar
org.eclipse.ui.navigator_3.4.100.I20090916-0800.jar
org.eclipse.ui.net_1.2.100.I20090714-0800.jar
org.eclipse.ui.views_3.5.0.I20090914-0830.jar
org.eclipse.ui.views.properties.tabbed_3.5.0.I20090429-1800.jar
org.eclipse.ui.workbench_3.6.0.I20090914-0830.jar
org.eclipse.ui.workbench.texteditor_3.6.0.v20090914-0800.jar
org.eclipse.update.configurator_3.3.100.v20090813.jar
org.eclipse.update.core_3.2.300.v20090525.jar
org.eclipse.update.ui_3.2.300.v20090813.jar
org.mortbay.jetty.server_6.1.15.v200905151201.jar
org.mortbay.jetty.util_6.1.15.v200905182336.jar
org.w3c.css.sac_1.3.0.v200805290154.jar
org.w3c.dom.events_3.0.0.draft20060413_v200905140418.jar
org.w3c.dom.smil_1.0.0.v200806040011.jar
org.w3c.dom.svg_1.1.0.v200806040011.jar
Installed the same installer on a few other macs seems fine, no problems. Only with my own mac..zzz. Wondering whats wrong, JAVA?
Weird... It could be something related to the permissions. Have you installed the software with a different user than the one you use to launch it?
