Problems while using transition effects in 'Set Active Panel'
Samir Bellare shared this problem 4 years ago
I'm using transitions in the 'Set Active Panel' effect. The effect is like swiping through cards. While using the 'Slide Left' transition (On swipe left, one card exits to the left, and the new card enters from right) it works fine. But I'm facing a problem in the prototype while using the 'Slide Right' transition. On swipe right, one card exits to the right, and the new card enters from the right too, but it should actually enter from the left. Can you help?
Hi Samir,
take a look to this example: https://www.justinmind.com/usernote/t...
If you have copied the actions, take a look because maybe you have forgotten to change some variable value or some effect.
Best regards.
