Problems opening Prototyper Pro 5.5 in Mavericks
Christian Florensa shared this problem 4 years ago
Since the update to 10.9 Mavericks, I have lots of issues opening the application. I need to try several times as it gets stuck. I have tried reinstalling and deleting the Justinmind library folder, but to no avail.
Am I the only one? It takes over 5 minutes of retries each time... (Application not responding is the result the first few times, eventually it opens up and works)
do you have an older version of Justinmind Prototyper?
delete /userfolder/justinmind/5.5.0/
if you have an older version, delete it. Then, download Justinmind Prototyper and install it. Don't use an older installer.
