Problems connecting to server floating license
islomse shared this problem 8 years ago
Please help me.
I'm having trouble logging onto a server license
I select the option:
I would like to obtain a license from the Licensing server
Then select the available server
And I choose: direct connection
The error that returns is:
Connection refused to host: localhost
I have a licensing server installed and I also have an Internet connection.aa56771f3cb2ca24b32c536971a38adf
Comments (6)
Please, could you tell me your name and company? so I can forward your problem to support.
Regards,
O nome da Empresa é Islo Setubal
E o nome da Empresa é Prodam Processamento de Dados Amazonas
Nos adquirimos as licencas flutuantes em outubro/2010
Regards,
The name of the Company is Islo Setubal
And the name of the Company's Data Processing Prodam Amazon
We acquired the licenses floating outubro/2010
Regards,
Correcting
"My name is" Islo Setubal - Manager
Regards,
Apparently, the problem is the configuration of your licensing server. Specifically, the error "connection refused to host: localhost" means that the file bin/server.xml must be changed to include the correct hostname instead of "localhost". This is explained in point 12, part 2 of the licensing server installation guide (http://bit.ly/9cf7JI).
Hope, this helps.
Best regards,
I forgot to tell you to continue this conversation via email. Could you send me your email to enrique.cano@justinmind.com?
regards,
