Problem outputting to html in 4.6 with a particular file
Rachel shared this question 6 years ago
I'm using 4.6 now, on Mac.
I have a file (let's call it "File A") originally created in 4.4, then edited in 4.5. In 4.6, I added some new screens (let's call this "File B"). When I export to HTML, I get an error message when, in the web browser, I click on links (in the left tree) to the screens that were created in 4.6. I do not get an error when I click on the links to the screens that were created in older version of Justinmind.
If I do a 'save as' on the file, I still get errors.
I tried testing some other files and didn't get an error. Including files that are:
• Created in older version; did not add anything or edit any in 4.6
• Created in 4.6
• I even reopened File A and added new screens in 4.6. I am able to export this successfully.
Could you contact to client support please? They might require you to take a look at the prototype file .
I did some more tests and it seems to be an issue just with the screens that have spaces and dashes in the screen title.
Example screen title: Lorem ipsum - 01
After I renamed those screens, they show up fine in the export.
Thanks for the help! I'll tell the development team to check it out.
