Problem copying .jim folder to server
julet shared this problem 7 years ago
I am experiencing the following problem with the newest version of jim. After exporting to html and copying the html to the server, I get an error when it trying to copy over the .jim folder. It doesn't like the "." before "jim." Is there anyway that this folder can be renamed to just "jim?" Right now I am doing a find and replace in all of the html files in order to replace the references to ".jim" to "jim" so that the css will look right on my server.
Thanks for your help!
I think your server might be blocking the access to folders that start with a dot. You can try to apply a rule in your server's configuration or just do the replace you talk about. Anyway in the next update we will change the name of that folder from .jim to _jim.
Fixed in the current version (4.4)
