Potential method to play sounds on button press?
JoJa15 shared this question 6 years ago
Is there a way to attach audio to a button press utilizing the web audio api?
Here is an example:
http://www.html5rocks.com/en/tutorial...
Could I utilize this method to play a sound on a button click?
If I used this method could I do so in a way that would not display any elements i.e. controls, the sound would play without anything else being visible to trigger it?
If I used this method would I have to provide direct links to the sound files on the internet or would the sound files be embedded in the .vp file?
Comments (6)
You can embed any HTML code into your prototype using the HTML widget. You can try with the example you have at the end of this tutorial: http://www.html5rocks.com/en/tutorial...
OK, I will give that a try.
Will the program embed my sounds in the .vp file or will I need to provide hard coded links to the files on the internet? I am assuming I will need to provide hard coded links?
Would it be possible to add a sound file as a pdf object and then somehow reference it from html? I could set the pdf object to not visible. If I could reference it from the html would I just put the name and no path or would I need to supply a path?
We're happy to inform you that Justinmind (version 7.9) now lets you embed .wav and .mp3 audio files in your prototypes.
This is a great new feature for adding rich, dynamic content to your interactive designs, and will give your prototypes an even more realistic edge.
Check it out for yourself here.
Hi Sonia,
This audio doesn't play if I launch my prototype outside of the simulator, eg as a published prototype in the browser.
Is it limited to paid subscriptions?
Ref: https://www.justinmind.com/community/topic/event-action-with-play-audio-does-not-work-outside-simulator
NJ
Dear Nipun,
Can you specify the computer/OS/Browser you are using?
Hi Sonia
Audio file is working great for me in the simulator on my computer, but not playing when I try to demo it on my phone through the JustInMind "view on device".
No audio plays (even with volume turned up) but my phone does seem to register that JIM is trying to play something... see screenshot attached.
Any ideas?
thanks
Jamie
