positioning widgets in datagrid
Thomas shared this problem 5 years ago
I created a datagrid with a free layout.
I only have one column so the data row (including the only cell in it) are configured to have a free layout.
Even though everything seems to be configured fine, when I add widgets to the datagrid aren't shown on the same position in the tool as in the simulation.
E.g. I added a line in the data row at position 0,30.
When I simulate though the line is shown at 0,50 (or something like that)
This happened to me yesterday too... I was trying to make something using an unified cell. In the end I had to change it, because the concept was not working for us. But if I had to go with it, it would be really a problem.
Here is a screenshot of inside JIM:
62a3fa44f6b38186c4ffd4c1f35a531f
You can see clearly that the line is OVER the image. But when I simulate this is what is shown:
The line slides down by some 15pixels or so... I guess the solution is tweak it until it is in the position you really want, even if inside JIM it is shown wrong... =/
So... same over here.
+1
also, nesting datagrids doesn't work.
These nested datagrids are always shown at the top of the cell (even though I positioned them exactly)
