Placing data grid inside dynamic panel screws up widget alignment
Marek Bowers shared this problem 4 years ago
When I add a data grid to a dynamic panel and view the simulation, the alignment of the widgets changes. Within JIM, the widgets are center aligned; however, in the simulation, they appear top-aligned (and look bad). This issue doesn't happen if I do not place the data grid in a dynamic panel. 017d844b2022fbe16fee6f54626e7639
Please check the alignment of the cell that is giving you trouble. If this isn't the problem could you send an email to jim.support@justinmind.com with the .vp file attached?
We will try to figure out what is going wrong and help you as much as we can.
Best regards,
Marc
