PDF Document doesn't load
onemhz shared this problem 6 years ago
I'm trying to use the "Document" widget to load a PDF, but all I get is a gray square where the PDF should be when I simulate. In the editor, it shows up fine, but during simulation, it seems to append %23toolbar=0&navpanes=0 to the URL, so it can't find the PDF file (the whole URL ends up looking like
<object width="801" height="543">
<param name="src" value="../../external/documents/c572d3ba-1036-4af6-9150-3c273d0c0372.pdf%23toolbar=0&navpanes=0">
<embed width="801" height="543" src="../../external/documents/c572d3ba-1036-4af6-9150-3c273d0c0372.pdf%23toolbar=0&navpanes=0" type="application/pdf">
</object>
Am I doing something wrong or missing a setting somewhere?
Comments (8)
Have you tried with the PDF widget that is already available in the widgets list?
Yes. Sorry, the PDF widget is called "Document" in my UI. f21368e1c1726bafb134539a4e729e8c
Yes, you're right. Is document, not PDF.
If you're seeing a grey box in edition mode is because your default browser (IE or Safari) doesn't have the PDF reader plugin installed.
I'm seeing the PDF in the editor mode. I'm not seeing it in the simulation. The URL it renders in the simulation seems wrong.
Then what happens is you don't have the PDF reader plugin installed in your browser
I do have it installed in my browser. If I use chrome's HTML debugger, for example, to remove the "%23toolbar=0&navpanes=0" from the generated PDF URL, it works.
You can try to use the HTML widget instead. That way you control the code.
