Password creation form
Jori Verbeek shared this question 2 years ago
I want to create an 'signup' form to create a new account. The password however should contain 8 - 32 characters, Upper and lower case characters, numbers and special characters. Therefore I want to create conditions before 'enter new password' can be succefull. If each condition is met, a tickbox will be ticked. For the first two I found out how to do this, however not for numbers and special characters. Anyone got some ideas how the condition should look like if i want to accomplish that?
cheers
Check out this tutorial to learn how to get started.
For the character count, you'll need to use the 'count' function.
For the special character, uppercase, and lowercase you'll need to use a custom regular expression. It should be this:
(?=.*[a-z])(?=.*[A-Z])(?=.*\W)
Then, combine all of that into a condition that will look like this:
649baacc073315ea23de41dcd23b43ae
Comments (4)
Hi Jori,
This tutorial should help.
http://www.justinmind.com/support/int...
Hello!
The link no longer exists... is there somewhere else I can check it out?
