Only one Dynamic Panel works at a time.
Amanda Li shared this problem 6 years ago
It seems in this latest update I have lost the ability to put a dynamic panel in another dynamic panel and still have the 2nd one be able to hold inputs, pictures and labels. For example. I have a dynamic panel #1, I draw a dynamic panel #2 inside it and attempt to add content to dp#2 and it all just goes into dp#1. If I try to manually drag it in in the screen it does not do anything. If I use the side 'outline' tab, it drags in and then I proceed to loose the ability to control the object I just dragged in at all.
I tried dragging dp#2 out of dp#1 and for awhile that worked, but now I literally only have one dynamic panel I can put objects into. This is very frustrating :(.
