non-JRMP server at remote endpoint
Marek shared this problem 7 years ago
When I try to start the prototyper 4.2.0 I get this error message " non-JRMP server at remote endpoint" and I can't open the software. I use licensing server with the port number 2099, because 1099 was in use. What can I do ?
Please use the client support portal http://support.justinmind.com with the credentials you received in the purchase email. They will help you better because they have the information about your license server.
Thanks for the answer. You're right. The solution was a new license file.
If you are using a port different from 1099 you will need a different license file.
