Need for Easy Accordion!
kkgokturk shared this question 6 years ago
After spending a few hours in customizing accordion and in designing my own one, I am about giving up on justinmind. Is there any easy way to add rows and resize all the content by just resizing the top panel?
Comments (4)
Take a look at this video tutorial, it might help you : http://www.justinmind.com/prototyper/...
I already did but it does not help.
I've run into the same problem...probably because my web skill set is the same as the authors (bottom 5%!). I didn't make it far into the instructions before...
"Then create four panels, each with one of the four states (I did get that "far"!!!) of your accordion: first option displayed, second option displayed, and so on." Where is "option displayed"? I was looking in the Properties box....
"Then it's time for some events. Select panel 1 and then select 'Item 2'." What.where is Item 2? I couldn't proceed without understanding "Items"
"And That's all" (ok, bottom 1%)
Doug
Hi Doug,
I understand your frustration, we should be more detailed in the tutorials. Let me try to help you a bit. The tutorial presumes you already know how to work with dynamic panels (which, I think, is the main problem with the tutorial). I suggest you to take a look at the dynamic panels tutorial first: http://www.justinmind.com/prototyper/... . Then, if you still need help, you just need to ask for it.
