Moving from one to another - Datagrids?
Don Roach shared this question 5 years ago
How do I get rows from Datagrid A to show up in Datagrid B when checked?
62595a722ef0425bdeb97ba6413d14cb
I followed this tutorial but it works with multiselect lists.
How could I use datagrids and checkboxes?
Comments (9)
More or less the same as explained in the tutorial but to get all the selected elements in the first data grid you need to build an expression like this:
filter(1st data grid, checbox)
1st data grid and checkbox must be dragged from the screen to the expression
Thanks, Victor,
Works perfectly as described.
One more question:
How can I UNCHECK the box on the left when a corresponding row is removed from the right? (see image)
f5a207dedde779151afa89cab1fd4d43
That's more hard to do. I'd define a boolean attribute on the data master to control which rows are selected. Then I'd link the check box with that attribute. Next I'd create an event that when you remove a row executes a modify action over that value in the data master and refreshes the data grid.
Thanks, Victor,
This is helpful. Can you show me how to assign a boolean attribute to the datamaster? Then I'll take a stab at the rest of it.
D
You create a new attribute on the data master and, as type, you set 'yes/no'. Then, you just need to select the check box in your data grid and select that attribute in Properties.
Got it - Thanks, Victor!
Glad to be helpful! Are you enjoying Justinmind so far?
I love it! I'm very impressed with the depth of possible interactions, and the speed with which you guys address questions on this forum is unbelievable.
How would you do this if Datagrid A was on a separate screen than Datagrid B?
