Move panels between two monitors makes them disappear
Andre Oliveira shared this question 4 years ago
According to this topic:
Pull-out panels for multi-monitor setups
( https://www.justinmind.com/community... )
You can move panels from Prototyper from one monitor to the other. But is this also in the Mac 5.5 version?
I can detach the windows, but when I try to move them to another monitor it does not work. They just disappear! The only way to get the window back is resetting the workspace.
Is this a feature or isn't?
Cheers,
André
(MacBook Pro 15" retina, Samsung monitor via HDMI)
Comments (4)
Hi Andre,
we need more information to try to reproduce this error.
Which version of MacOS are you using?
Are you using prototyper in fullscreen?
Best regards
I am using Mavericks with Prototyper >not< running fullscreen.
I took a photo so you can understand better what is happening. I believe this has something to do with the "Retina" of the MBP.
Mind you that the problem also happens the other way around, using the MBP as main screen and trying to move a window to the external monitor.
4891257e8d176adcfaf5db2a93d1f333
BR,
André
Go to system preferences, mission control and deactivate "displays have separate Spaces" and then log out.
We will fix it as soon as possible.
Sorry for the inconvenience.
Thank you for the fix Albert. Since I don't use Spaces it's really not a problem for me. =)
Keep on rockin'!
