Move function not working
Peter Giza shared this problem 6 years ago
Move function suddenly doesn't function. I've tried everything and I cannot move _any_ object using Move. Worked fine yesterday.
Comments (6)
Let me qualify that statement. The problem only seems to exist when using Move in a Master. If I build it in a screen it works fine.
Mmmm it looks like a bug. Could you send us an example of that to jim.support at justinmind.com please?
I deleted all my masters because they were rendered useless by this bug. You can reproduce it pretty easily. Just create a master, add a dyn_panel, add a rectangle, add a button. Set an interaction on the button to Move the rectangle 200x200 and watch it fail.
Yep, that's a really annoying bug. Working on it.
Fixed in version 5.5
I'm trying to make a slider(add event -->"on drag"---> move with cursor on x-axis constrained by parent container) in a master screen but I'm running into the problem of it not working. I've copied and pasted the same slider into a normal screen and it works fine.
Is there anything I can do to make the slider work in a master screen?
