Modify some register on datamaster using only one button
maira.khouri shared this question 7 years ago
How to modify a datamaster with some registers using only one button?
Each row has a different value to change.
Could you detail your case a little further please?
The column "Qnt. a ser Liberada" is part of the datamaster "Ingressos".
By filling out the fields that are in this column and click on "Liberar Ingressos" which was fill in the fields should be saved (using modify) the "Qnt. a ser liberada" from datamaster "Ingressos", because they will use data on another screen.
Please, see the screen attached.
I'm sorry but I think you didn't attached the image. I presume you have a data grid where the column "Qnt. a ser Liberada" can be edited by the user and another column with a button that saves the change. If that's the case then you have to create a data master event with a Modify action and place the row as the item to be modified.
I hope that helps you.
