missing table cell when running in usernote or exported html
Tod Jackson shared this question 7 years ago
The screen shots below show a table when running in the simulator vs. the same table when running the prototype via usernote. The same thing happens when running the exported HTML locally. It happens in other areas of this particular prototype but I can't quite figure out why. This is a table from the iPhone widget library. I searched the forum but couldn't find anything similar so hopefully it's just something I'm doing.
Any assistance would be greatly appreciated.
Thanks,
Tod
adf0ae68c171046756c8a649a3da2156
Comments (8)
hi Tod,
could you please share with us your version of Justinmind Prototyper. i was cross-checking your problem and thought this issue has already been resolved. the image drawing the rounded borders is transparent, which it obviously shouldn't be.
Hi Burk,
I'm running prototyper version 4.1.1 on Mac OS X (10.6.7).
Also, I created another prototype that contained just an iPhone table widget with no changes at all, i.e., I just dropped the widget on the screen and exported to HTML. It's demonstrating the same behavior.
Tod
Based on your comment regarding the rounded boarders, I changed them all to be square and they do show up now. So, I guess that is the cause and apparently, it still is an issue at least with the version I've got.
Thanks,
Tod
We will check it out for the upcoming update on April 26th. Thanks!
Is this going to get fixed? I'm getting the same behavior with the rounded corners.
It should be already fixed in the current version (4.3.1)? Can you post an image with an example of that bug please?
The bug is still happening in Mac OS with Prototyper 4.3.1. The next update (coming tomorrow) will have this fixed.
OK thanks!
