MenuItem vertical size incorrect in Simulation
geraud B shared this problem 5 years ago
I am using the Menu widget to make a Side Bar with 6 Items. (stacked vertically)
Since there does not seem to be a setting to change each item's height apart from, I expect the text size to drive the MenuItem's size.
However, in the Simulation, all MenuItems are smaller (vertically). It looks like it's not taking into account the padding (although padding is not a parameter of the MenuItem). The result is a text that is only 1 or 2 picels away for the border of the menuitem, and the whole layout that looks messed up.
The PDF export looks fine though.
