Masters eventually delete all their event interactions
Carlos shared this problem 7 years ago
I constantly end up losing all the event interactions of certain masters, forcing me to create the interactions again and again, and making the use of masters of little use. There must be some bug whenever a master is broken in a screen and/or whenever I undo the break master, that ends up deleting the event interactions of the original master. I never touch the original master.
I have prototyper 4.3.1 for PC.
Comments (6)
My goodness! Could you reproduce the error step by step please?
So far, it appears not to be occuring with version 4.4 (I was using the previous version, 4.3.1). If it happens again, I'll notify you.
Thanks,
Carlos.
Please do! If it happens again it should be fixed asap.
I have this issue. And it seems that if I delete a dynamic panel which contains an instance of the master, the events inside the master get deleted as well.
That costed me 2 hours of work.
Good that I make backup of my work.
Please fix.
I have Version (Ver. 4.4.1)
The workaround is to remove the master from the dynamic panel before deleting the panel. That way the master still retains it's event interactions.
We can't reproduce the error. Could you send us an example please to jim.support at justinmind.com? Could you try it with the new 4.5 version as well? Thanks in advance.
