master header / footer...?
Wayne Granzin shared this question 5 years ago
is there a way to have something that doesnt change (like a footer nav bar) when the rest of the screen content transitions?
Yes but then you need to specify the content inside a dynamic panel instead of having several screens.
can you elaborate on that a bit?
Take a look at this tutorial to learn more about how to use dynamic panels:
The option 'set active panel' also has the same transition effects as the screens. So you just need to place what it would be several pages inside several panels. Then, draw the toolbar above the entire dynamic panel.
