Master-detail grids
Oleg Ippromek shared this question 4 years ago
HI guys, is there any way to set up master-detail grids ? To have a connection between two grids in one screen - if I select a row in a master grid, a detail grid should be filtered by some value from a master grid (both grids have a common column)
Hi Oleg,
I share with you some topics and tutorials that maybe helps with your project:
Filter datagrid column on multiple values
How to edit rows using check boxes in your web prototypes (Data grid batch update)
How to edit rows in a Data List in your web prototypes
If you need more help, please gives us an example of what you would like to do.
Best regards.
