MacBook Retina Support
William Li shared this problem 6 years ago
Can you add MacBook Retina support? right now some items are just too small to see. 89a9c3baca600d1e72312e267f2c9e2d
Comments (30)
Eventually.
Could you be a little more detailed on when this might be supported? I loved the app, but it's pretty bad on a retina MBP 15. If support is coming soon, I'll wait but if not, I need to find another solution.
I'm afraid we don't plan to fix this until 2013. Sorry for that.
This should be high priority, guys. Your target users are going retina, fast.
For this reason we are buying Axure licenses as we speak, and may or may not go for Justinmind ultimo 2013 :(
Ok, working on it!
We found a way to fix it manually while we launch a version that has that fixed.
The text size will be displayed correctly if you replace the ‘Info.plist’ file by this one http://d2ld3he4yll0xl.cloudfront.net/Info.plist. You can access to this file if you go to /Applications right-click on ‘Prototyper Pro’ application select the ‘Show package contents’ option and then open the contents folder.
Thanks Victor. I followed these steps and still have an issue. Any other steps after copying the file?
You might need to do a fresh install (sorry)
Please follow the next steps:
1.Close the application and remove “Prototyper Pro” from Applications.
2.Go to ‘your user’/Justinmind and rename that folder (just in case).
3.Install Prototyper Pro v5.1 again, but don’t open it yet.
4.Show the application package contents and replace the “info.plist” by the file I sent you previously.
5.Start the application
Thanks again Victor. My computer rebooted on its own and that took care of the problem. It looks/works great!
Good! So you didn't need to install Prototyper again?
Wanted to try the software today but unfortunately it's unusable on my MBP retina. I guess this isn't a high priority for the developer, which is unfortunate as it looks good but just too hard to read anything to use on a regular basis.
The text size will be displayed correctly if you replace the ‘Info.plist’ file by this one http://d2ld3he4yll0xl.cloudfront.net/.... You can access to this file if you go to /Applications right-click on ‘Prototyper Pro’ application select the ‘Show package contents’ option and then open the contents folder.
Then reboot your computer
For some reason, I cannot download the file attached to the link. Is the link still working?
It is, but you don't need that file any longer if you use the new version (5.5)
I just updated to version 5.5.0, but that doesn't make a difference. Text labels are still very small and the text I see when editing does not correspond with the text I see when I open my prototype in a browser.
1e9096f4dfebc484af6efb107ad882eb
I'm sorry, you need to do a fresh install to make it work.
Yes, works!
Thanks for the help!
Fixed in version 5.5
Hello! Tried updating to 5.5, completely removed the app and plist and reinstalled but it's still non-retina. Any other suggestions? Thanks!
255a781f0cae8453b8c4476164e59183
Hey Brian,
Is the retina settings in your computer the basics or you changed something in the config panel?
Hey John, Nope, normal settings all around. The only thing unusual about my setup is that I'm running Mavericks (the final GM that will be released later this month)
Hi Brian,
Your issue is different from what's posted above. Their issue is on typography but yours is blurry in typography and UI elements. Your issue is because the actual version of prototyper is not compatible with Retina Resolution.
Our engineers will fix it for future versions. Sorry for the inconvenience.
I am running into the same issue. Any idea when retina compatibility will be made available?
Hi Mario,
I am not sure but I will post the info here when I got the exact date.
Just installed the latest version and still no retina on version 5.6. What is the deal with this ? any fixes ??
The issue has been fixed in version 6.1
Very cool – thanks for following up.
8e60d21a39a249ecddae57ab6ae4f7eb
Downloaded it a couple of weeks ago. Having the same issue described.
Was working fine when I ran on my external display but on my mbp retina the fonts are unreadable.
Fixed in version 6.5
Similar issue on Windows (!) Lenovo Yoga Pro 3. Any suggested fix for windows users?
b42fe28999744fde28a222f7f91c7467
