Mac-trial fails to open...
Niels Joormann shared this question 7 years ago
I just downloaded the Mac-trial from your website. As I try to open it, it displays an error-message "An error has occurred" and it fails to start. How can I solve this?
Comments (15)
Hello Niels,
Could you please check if any .log file was generated in the 'configuration' folder specified in the error dialog and print its content here?
!SESSION 2011-10-09 15:11:46.359 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_26
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=nl_NL
Framework arguments: -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.0.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86 -data @user.home/Justinmind/4.4.0 -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.0.app/Contents/Resources/Java
!ENTRY org.eclipse.equinox.app 0 0 2011-10-09 15:11:50.392
!MESSAGE Product com.justinmind.evc.EVC could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-10-09 15:11:50.568
!MESSAGE Application error
!STACK 1
org.osgi.service.application.ApplicationException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:262)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
The problem could be related to permissions..have you installed the software with a different user than the one you use to launch it?
Also, there are known issues regarding java and Lion. What OS version are you using?
I am the only user of my Mac, but I do have Lion yes.
Could you please try to install java again from here :http://support.apple.com/kb/DL1421?
I installed the Java-app, but it still doesn't work. Here's the log-file:
!SESSION 2011-10-10 18:13:46.510 -----------------------------------------------
!ENTRY org.eclipse.equinox.app 0 0 2011-10-10 18:13:56.658
!ENTRY org.eclipse.osgi 4 0 2011-10-10 18:13:57.074
!STACK 1
Could you remove the app from your file system, download it again from our website and install it please? It looks like it hasn't installed correctly.
Now I have removed the app, and reinstalled it. But it still doesn't work. Here's the new log file:
!SESSION 2011-10-15 13:40:57.471 -----------------------------------------------
Framework arguments: -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.1.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86 -data @user.home/Justinmind/4.4.1 -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/JustinmindPrototyper_4.4.1.app/Contents/Resources/Java
!ENTRY org.eclipse.osgi 4 0 2011-10-15 13:41:06.305
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
at javax.xml.parsers.SAXParserFactory.newInstance(SAXParserFactory.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.createService(EclipseAdaptorHook.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService(EclipseAdaptorHook.java:142)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:138)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:136)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:450)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:980)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:185)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getXMLParser(RegistryStrategyOSGI.java:304)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1062)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1040)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.addBundle(EclipseBundleListener.java:184)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.processBundles(EclipseBundleListener.java:90)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.onStart(RegistryStrategyOSGI.java:224)
at org.eclipse.core.internal.registry.ExtensionRegistry.(ExtensionRegistry.java:725)
at org.eclipse.core.runtime.RegistryFactory.createRegistry(RegistryFactory.java:58)
at org.eclipse.core.internal.registry.osgi.Activator.startRegistry(Activator.java:137)
at org.eclipse.core.internal.registry.osgi.Activator.start(Activator.java:56)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:460)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClass(MultiSourcePackage.java:31)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at org.eclipse.equinox.internal.app.Activator.start(Activator.java:55)
at org.eclipse.core.internal.runtime.PlatformActivator.startAppContainer(PlatformActivator.java:44)
at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:31)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1130)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2011-10-15 13:41:06.307
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.ServiceException: Exception in org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:148)
Caused by: javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
... 77 more
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.309
!MESSAGE Could not parse XML contribution for "org.eclipse.core.runtime//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
org.xml.sax.SAXException: Could not acquire XML parsing service.
at org.eclipse.core.internal.registry.ExtensionsParser.parseManifest(ExtensionsParser.java:392)
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.323
!MESSAGE Could not parse XML contribution for "com.justinmind.evc//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.331
!MESSAGE Could not parse XML contribution for "org.eclipse.ant.core//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.337
!MESSAGE Could not parse XML contribution for "org.eclipse.core.contenttype//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.348
!MESSAGE Could not parse XML contribution for "org.eclipse.core.expressions//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.398
!MESSAGE Could not parse XML contribution for "org.eclipse.core.filebuffers//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2011-10-15 13:41:06.404
!MESSAGE Could not parse XML contribution for "org.eclipse.core.filesystem//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
It seems like the java virtual machine is going crazy. Could you try this please?
Open Finder and then open this folder
/System/Library/Java/Extensions
Rename it to /System/Library/Java/Extensions.old (or any other name)
Open a console and execute the Justinmind's app with the parameter -clean
If that works please tell us.
We've found how to fix this error but we don't know which software copy those corrupted libraries in Mac systems.
- Open Finder and then open this folder
- Remove all the files inside that folder
- Reinstall Justinmind
Hello Victor,
I've tried all the steps you described but the program JUST WON'T WORK!
!SESSION 2013-09-22 10:21:24.799 -----------------------------------------------
java.version=1.6.0_51
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=nl_NL
Framework arguments: -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Free.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/Justinmind/Free_5.5.0 -keyring /Users/nielsjoormann/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Free.app/Contents/Resources/Java
!ENTRY org.eclipse.equinox.app 0 0 2013-09-22 10:21:37.783
!MESSAGE Product com.justinmind.evc.free.EVC could not be found.
!ENTRY org.eclipse.osgi 4 0 2013-09-22 10:21:40.811
!STACK 1
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Hi Niels,
Please could you follow these steps?
1. Remove Prototyper Free from Applications.
2. Install Prototyper Free again.
3. Before you open the application for the first time after you install it, open Applications right click on it an select the "Show Package Contents" option.
4. Go to /Contents/MacOs/ and open the file "Prototyper Free.ini" with a text editor.
5. Add this line and the end of the file:
-Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl
6 .Launch the application.
e3a811cc6e97a3c852ed85194c475dc8
Hello Carles,
I've followed all your steps, and guess what: it doesn't work! Here's the new log file:
!SESSION 2013-09-23 16:50:23.796 -----------------------------------------------
!ENTRY org.eclipse.equinox.app 0 0 2013-09-23 16:50:26.957
!ENTRY org.eclipse.osgi 4 0 2013-09-23 16:50:27.849
!STACK 1
HI Niels,
Please could you send your edited '.ini' file to jim.support[at]justinmind.com ?
Also, it will be helpful if you can send us a screenshot showing the contents of the next folder:
Best regards.
This problem will be fixed from version 5.6
Meanwhile the issue could be solved following these instructions:
1. Close Prototyper if it's open.
2. Open Finder and go to the next folder: "your user folder"/Justinmind
3. Delete all the contents on this folder.
4. Go to Applications.
5. Right click on the Prototyper app and select the "Show Package Contents" option.
6. Go to /Contents/MacOs/ and open the file "Prototyper Free.ini" with a text editor.
7. Add this line and the end of the file:
8 .Launch the application again.
cb7323709fc0f6e27f342f8214c9adcf
