MAC Mavericks Crashes, Bugs, and Annoyances
twenty3x shared this problem 4 years ago
• Prototyper keeps crashing after being open 8 + hours and I lose saved work.
• Doesn't support dual monitors, I'd love to bring toolbars to second monitor but can't
• I can't use the properties menu properly, because the double arrows have opposite effect when clicked. Click down value goes up, click up value goes up. Type in value it remains the same.
• Typing in values for labels disappear after editing and clicking in doc cant be undone.
• Editing table column widths, sometimes causes funky table resizing that cant be undone.
I want to like prototyper but it is very frustrating.
Comments (5)
In bold are your issues and below the answer to each one.
"Prototyper keeps crashing after being open 8 + hours and I lose saved work."
If the project is saved you shouldn't have any problem. But you can also save it in Usernote so it isn't lost and you also have the File->Recover Prototype... option which will recover the prototype you choose from the prototypes automatically saved by Prototyper. Also, this should be solved in the next softare update. Could you download the beta version and let us know if it works in your computer? (Link at the bottom of the post)
"Doesn't support dual monitors, I'd love to bring toolbars to second monitor but can't"
This should be solved by deactivating "Displays have separate spaces" in Mission Control in System Preferences (will ask you to log out and log back in).
This work-arround shouldn't be needed in the next version. Could you download the beta version and let us know if it works in your computer? (Link at the bottom of the post).
"I can't use the properties menu properly, because the double arrows have opposite effect when clicked. Click down value goes up, click up value goes up. Type in value it remains the same."
This should be solved in the next softare update. Could you download the beta version and let us know if it works in your computer? (Link at the bottom of the post)
"Typing in values for labels disappear after editing and clicking in doc cant be undone."
AND
"Editing table column widths, sometimes causes funky table resizing that cant be undone."
Could you send a video showing this behaviour to jim dot support at justinmind dot com so we can look into it with more detail?
Here is the link from where you can download the beta version: https://www.justinmind.com/usernote/t...
Marc
The good news is the beta seemed to fix all my issues. The bad news is I can't share prototypes, and the rest of my team can't get beta. I could make do if I could publish prototypes but at least i have dual monitor support thanks! 57db174cd5f21672747670565daaef11
This is temporary since you are accessing the server configured for v5.6 but using v6.0. There have been a few changes that make it incompatible. As soon as the software is released (not beta) and the server updated for v6.0 you will be able to work perfectly.
Marc
There is a special usernote for the beta. Open Justinmind and go to Preferences -> Justinmind account and change 'http://23.23.122.164/usernote/
Marc
You can now switch back from the test usernote to the new version of usernote.
To have all the prototypes from the test usernote in the new usernote please:
1) download the .vp files to your computer.
2)Open Justinmind and go to Preferences -> Justinmind account and change 'https://www.justinmind.com/usernote'
3)Upload the prototypes to the new usernote either from prototyper or from the browser.
Best regards,
Marc
