Links within masters do not work
Christian Kravogel shared this problem 6 years ago
I have added a master containing the menu from the navigation widget. But when I insert this master into a screen, the links inside the menu no longer work.
If I copy the menu into the each screen it works, but then I loose the advantage of masters. How can I proceed?
Comments (6)
That's weird, the links should work. Could you send your .vp file to jim.support at justinmind.com please? We will have a look at it.
Having a similar problem - links on sub-menu items inside a master don't work, but links work when copying the menu directly into a screen.
Only sub-menu items are affected - top level menu item links work OK.
Confirmed, it's already fixed for the next update. We will launch the new update in 3 4 weeks. Thanks for your help.
I am having a problem with this same issue.
The components in the header linked to a screen work in simulation mode.
The sub-headers do not work in simulation mode.
It's a known bug and it has been fixed for the next update. You will be able to try the new version in a couple of weeks hopefully.
Fixed in version 5.6
