Links in masters break sometimes.
David Hinnergardt shared this problem 6 years ago
When I create links in a master an drag them on to a page sometimes (but not always) the link get broken an points to a different location in the prototype. Why would this be happening?
Sorry David, we could not reproduce this behaviour. Could you please specify how your events were created and in which elements? What Justinmind Prototyper version web browser are you using to simulate? Thank you
The master element is a simple header with a series of links. The events were added via the event pane and are simple on click conditions. When we drag the master onto a page it occasional changes the link destination to a random page (it does not happen every time.)
As a work around were duplicating the header on every page.
Would you mind sending a prototype where this problem is actually happening to: jim dot support at justinmind dot com? We'll get back to you once we find the source of the problem. Thanks for your feedback!
