Labels as links not working in IE8
Mackan shared this problem 5 years ago
My labels which links to subpages does not work in IE8 for some reason. Running IE8 as mentioned.
Thanks for letting us know. Maybe you can upgrade to IE10?
I did, still not working, it doesn't recognize the label as a link.
Correct me if I'm wrong but I think that you want to link labels in the same screen, don't you? If you want to link two elements from the same screen, you have to use the "set focus on" event. Just select the label and add an event. Now, select "click" action and "set focus on" and choose where you want to go in the same screen. Here you have an image of how to do it.
eafcf3399af1b6b7c32d03c0a45813fe
I hope it helps you.
