justinmind Slider set value to variables
Jan Fuxa shared this question 2 years ago
Hi, i have problem with setting value from slider in justinmind. I prototype a mobile app for smarthome app. I need slider for setting temperature.
I have function that when i drag the slider then the value is increasing --> variable + 1, but i dont know how make decreasing on the other side, how recognize the direction dragging move.
PLEASE HELP ME....
Comments (8)
Hi Jan,
You should do the same when decreasing the values --> Variable -1.
Also, to recognize the direction when dragging you should use the "on drag start" then keep the position into a variable. Then use the "on drag" using the current position minus the last position.
I hope this helps,
Could i send my file with prototype and you make it ? Its posible ?
Hi Jan,
Usually, we do not create prototypes. If you want to share with us the vp file here (via dropbox/wetransfer) and I will have a look to your prototype.
Thank you so much.
1c10310a67b508943736db3f20fba0e1
I upload this prototype on dropbox and then i put link there, you could see slider on the bottom on the screen and label with number "24". I need value from slider to label.
https://www.dropbox.com/s/bzgttjniyzr...
I shared prototype via dropbox, could you look at on this ?
here you are your slider modified. In case you want to modify the first and last value, you can do it at the expressions tab.
https://www.dropbox.com/s/cf5ozo6g7tz...
b2625273c68bb8df54e65b0ee6f69b5c
I hope it helps.
