JIM 5.0 on Mac 10.6.8 corrupts files with no possibility of recovery.
Samuel Asher shared this problem 6 years ago
I'm getting a "File error" when trying to open a prototype I closed just an hour ago. Using the latest Justinmind Prototyper Pro Edition Version (Ver. 5.0.0) on my Mac OS 10.6.8. The last 3 backup files all fail with the same error. Is there a known bug I'm running into, here? I have dozens of hours in this. I save early and often. It's frustrating to say the least.
Comments (5)
Sam,
So sorry to hear about your problem. I'm evaluating JIM for purchase and looking at comments to get a sense of the support team responsiveness. This doesn't look good! I hope they get back to you with a fix!
Paul,
Truth is, they have been extremely helpful. I should have posted it here earlier. They acknowledged there was a bug in the way I was using one of the features. The corrected my file and I've been using a work-around until they get the fix in the next update.
-Sam
Resolution:
There is a problem in JIM 5.0.0, when you create a Data Master record with a Category or Multi-Category field that has no data populated. This is what corrupts the working prototype file.
There are several work-arounds. One that has worked for me is to create the field in the Data Master with type "text", then represent the field as a "select box" (category) or "multi-select box" (multi-category) widget in your prototype.
Another option is always to populate your category field with data immediately when you create the field.
I was told the fix will be in the next maintenance release of JIM, which should be available in a couple of weeks.
Sam,
Thank you for the update. That's great news! I like the tool so far, but haven't been able to do everything I've wanted to do with it, but so far there is a lot to like.
fond regards,
Paul
This is bad news and may be related to the fix I'm in.
See here:
Broken links in completed prototype
Thank you
