Is there a way to create a persistent header, like twitter.com? Where it sticks to the top of the screen while scrolling.
Jess shared this question 5 years ago
Comments (7)
Take a look at this other thread https://www.justinmind.com/community...
Yeah, thanks. But I still cannot get it to work. Im not sure what setting "with scroll" is.
But I have a dyanmic panel with content in it. Another image always on top. The image does not float at all.
The image should be out of the dynamic panel. You can check if it's out or inside in the Outline tab.
It is, http://i.imgur.com/acIPNxn.png Img 4 should float.
Can you clarify how this works? Its pretty unclear to me still and the "always on top" setting doesnt work like I would expect at all. Thanks
Take a look at this example:
I can ́t believe that this is the only solution to build fixed areas like the statusbar of iOS. This would mean if I would like to have ONE static header/statusbar for
the whole prototype then I need to build EVERTHING in a dynamic panel.
This would be not very satisfying.
I could imagine to have setting in templates allowing to fix the content, means if there is a transition from one screen to another the template keeps staying at its
position all the time (just like the statusbar in iOS or Android is doing)
