Is there a way to change the text of the On / Off toggle under sketch switches?
Jeff Haddick shared this question 4 years ago
Instead of it saying On/Off I want it to be yes / no thanks.
Hi Jeff,
you can create your own toggle widget with the text yes / no thanks. Just drag the active image to the canvas, select it and create a toggle action. Choose "set value" action, select the image and on the calculator choose the other image for the toggle.
Now, drag a label under the image toggle and write the text "yes". Then, click again on the image toggle and add another action next to the previous one. Choose again set value but this time select the label and write on the calculator, no thanks.
Best regards
