is it possible to replace image with interactions on it?
davidicus shared this question 6 years ago
if i insert an image, then add Interactions to it, what's the best way to replace that image? i can't find a Relink command, for instance.
it looks like if i insert the replacement, copy/paste the interactions over, delete the original, and rename the new replacement to match the original, any Actions that refer to the original disappear when it's deleted.
Just double-click on the image and then select another image file. That way you won't need to change any event.
